This page provides information on the Post Translate tab of the V-Ray Renderer settings.
The Post Translate tab exposes options for Python Post Translate of .vrscenes. You can import a script file or write a script directly in Houdini to control plugin parameters.
The V-Ray for Houdini's Post Translate support is based on AppSDK Python binding.
UI Paths:
||out Network|| > V-Ray > V-Ray Renderer > Post Translate tab
||V-Ray Shelf|| > ROP Parm > Post Translate tab
V-Ray menu > Render Settings > Post Translate tab
import os import vray from vfh import vfh_utils with vray.VRayRenderer() as renderer: for plugin in renderer.plugins: vfh_utils.logInfo('plugin ' + plugin.getName() + ' (class ' + plugin.getType() + '):\n') |
import vray r = vray.VRayRenderer() p = r.plugins["|mat|vrayMaterialBuilder|vrayMtl"] p.diffuse = vray.AColor(0, 1, 1, 1) |
import vray from vfh import vfh_utils renderer = vray.VRayRenderer() for node in renderer.plugins: if node.getType() != 'Node': continue if not node.object_properties: continue objProps = node.object_properties needFix = objProps.camera_visibility == 0 or objProps.matte_surface == 1 if not needFix: continue instancer = node.geometry if not instancer.instances: continue for instance in instancer.instances[1:]: # First item is time instancedNode = instance[-1] # Node is last if type(instancedNode) is not vray.Plugin: continue if instancedNode.getType() != 'Node': continue if instancedNode.geometry.getType() in {'GeomDisplacedMesh', 'GeomStaticSmoothedMesh' }: instancedNode.geometry = instancedNode.geometry.mesh vfh_utils.syslog("Disabling displacement for \'%s\"" % instancedNode) |
Here, you can check how the script changes the render.
import os import vray import subprocess from vfh import vfh_utils def convertToTX(f): make_tx = os.path.join(os.environ['VRAY_APPSDK'], 'bin', 'maketx.exe') cmdArgs = [ make_tx, f ] call = ' '.join(cmdArgs) proc = subprocess.Popen(call, universal_newlines=True) proc.communicate() return os.path.splitext(f)[0] + '.tx' with vray.VRayRenderer() as renderer: for plugin in renderer.plugins: if (plugin.getType() == 'BitmapBuffer'): if(os.path.splitext(plugin.file)[1] != '.tx'): if( not os.path.exists(os.path.splitext(plugin.file)[0] + '.tx')): plugin.file = convertToTX(plugin.file) else: plugin.file = os.path.splitext(plugin.file)[0] + '.tx' |
