Animation Keys – Deletes all animation keys in the scene. Animation Layers – Deletes all animation layers in the scene. Bitmap Chache – Frees up all the memory used by the image file bitmap caches. This is useful if memory is fragmented with a lot of different bitmaps and you want to have just ones currently active reloaded. This operation is not undoable. |
Block/Style Parent Object – Deletes all nodes containing Block/Style parent object in the scene. Empty Layers – Deletes all empty layers in the scene. MAXScript Memory – Excludes MAXScript's garbage collector, potentially freeing up some memory MAXScript was using. This operation is not undoable. |
Note Tracks – Deletes all note tracks in the scene. All Retimers – Deletes all retimers in the scene. All Retimers With No Markers – Deletes all retimers with no markers in the scene, i.e. empty retimers. This operation is slower than deleting All Retimers. |
Particle View Objects – Deletes all Particle View related helpers and objects. Undo/Redo Stack – Empties the Undo/Redo stack. This operation is not undoable. |
Unresolved XRefs – Deletes all unresolved XRef objects and XRef scenes in the scene. This operation is not undoable. |
Select All – Selects all Scene Cleaner checkboxes. Select None – Deselects all Scene Cleaner checkboxes. Apply – Runs all selected cleanup tasks.
