In this chapter we'll talk about an important part of the proper functioning of the AppSDK - obtaining licenses from your code to unlock V-Ray.
The new online License Server, available at download.chaos.com, provides you with a fast and secure way to license both current products and those we plan to release in the near future. As opposed to the old hardware licensing system that required a local (USB) dongle, there's no need to wait for a physical device to be shipped to you. We hope this provides all our users with a better experience with our products and the ability to change their applications needs faster to be able to stay productive.
The legacy licensing system is still available within the new Online Licensing system and active USB dongles are not phased out with this new setup. This new system introduces real-time license activation with highly encrypted communication between you and the license servers. This new system also makes it possible to borrow licenses and be completely offline without having to remember a hardware dongle or dealing with what happens if you lose it. The real-time updates means you don't have to wait for emails to be sent back and forth with the Support Team to get your software licenses up and running. It is also completely integrated into the current Ordering System when you need to purchase more licenses.
The AppSDK license is obtained automatically once the first renderer is created. If you don't have an AppSDK license available renderer creation will fail.
The Render Node license is also checked when a renderer is being created and if not available, the renderer creation fails. This check serves as an early warning and can be suppressed in RendererOptions.noRenderLicensePreCheck
. The Render Node license is obtained when the actual rendering starts. Again, if you don't have a Render Node license, the render start call will fail.
The Render Node license is released when rendering stops, whatever the reason. If communication with the license server is disrupted, the license will be released after a certain timeout.
The AppSDK license is released when the AppSDK module's deinitialization method is called, which happens implicitly. For Node.js and Python this means vray.close()
, for C++ it's the destructor of the VRayInit structure, for C# it happens completely under the hood. All these methods are called automatically by the SDK, so the user generally should not care about releasing the UI license.
If you install the license server on the machine that runs V-Ray its installer takes care of configuring your system to use it and you don't need to take further action. But you may want to use an alternative server or set up the server on a machine that has no prior configuration. You can use the setLicenseServers
global method for this. See the code comments for usage details. Make sure you call this before creating a VRayRenderer or VRayServer object, because their constructors require a license.
For more information, see the Chaos License Quick Start Guide page.
