This section describes the input sockets of the node. The sockets have dedicated parameters, which are further described below.
Mapping – Allows a UVW Mapping or a UVW Randomizer node to be connected to determine the mapping of the ramp. Color 1 (input socket) – Controls the first of the two colors used by the Noise procedural. Color2 (input socket) – Controls the second of the two colors used by the Noise procedural. Threshold (input socket) – Specifies a value added to the noise function. Note that values above 1.0 are clamped. Scale (input socket) – Controls the scale for the noise UVW coordinates. Origin (input socket)– Controls the translation for the noise UVW coordinates. Implode (input socket) – Controls the amount of implode performed on the UVW coordinates. Implode Cen (input socket) – Specifies the center of the implode effect. |
