This page provides information about the Granite texture in V-Ray for Blender.
The Granite texture map generates a procedural Granite texture. It uses four colors that can be changed or assigned to texture maps.
UI Path: ||V-Ray Node Editor|| > Shader > Add > Textures V-Ray Granite
Node Input Sockets
This section describes the input sockets of the node. Some sockets have dedicated parameters, which are further described below, and some sockets are just inputs.
Mapping – Allows a UVW Mapping or a UVW Randomizer node to be connected to determine the mapping of the ramp.
Color 1,2,3, Filter (input socket) – Allows color nodes to be assigned as the colors of the Granite texture.
Cell Size (input socket) – Allows an integer-outputting node to be connected as the Cell Size parameter.
Density (input socket) – Allows an integer-outputting node to be connected as the Density parameter.
Mix Ratio (input socket) – Allows an integer-outputting node to be connected as the Mix Ratio parameter.
Spottiness (input socket) – Allows an integer-outputting node to be connected as the Spottiness parameter.
Randomness (input socket) – Allows an integer-outputting node to be connected as the Randomness parameter.
Threshold (input socket) – Allows an integer-outputting node to be connected as the Threshold parameter.
Common
Compatibility With – Allows you to match the result of the texture in Blender to that in either 3ds Max or Maya. If Alpha From is set to Maya:
3ds Max – The resulting alpha of the texture is the intensity of the texture.
Maya –
The resulting alpha of the texture is the color luminescence.
 Alpha From Intensity – Determines how the alpha of the result is calculated:
Bitmap Alpha – The Alpha channel is drawn from the texture.
Color intensity/luminance – Alpha is generated from pixel intensity.
Force Opaque
– Alpha channel is fully opaque.
Invert – When enabled, inverts the colors in the final result.
Invert Alpha – Inverts the alpha channel if Invert is also enabled.
Color Mult  Corrects the color of the texture by multiplying the color values in the texture with the color values specified here.
Color Offset  Corrects the texture's color by adding the RGB color values specified here to the color values of the texture.
Alpha Mult – A Multiplier for the Alpha value.
Alpha Offset – Determines the offset value for the Alpha.
No UVs Color  Specifies a default color used for polygons with no valid UVs. In case the map is not tiled, specifies a default color that is used outside the texture square.
Mapped
UV noise phase –  Specifies the UV noise phase.
Color 1 – Specifies the first color of the spots.
Color 2 – Specifies the second color of the spots.
Color 3 – Specifies the third color of the spots.
Filler ColorSpecifies the color that fills in the area surrounding the spots.
Cell Size –  Controls how large or small the cells are.
Density – Controls how closely packed the spots are.
Mix Ratio – Controls the prominence of each color relative to the others.
Spottiness – Controls how circular the spots are. Lower values make the spots more circular, and higher values make them less circular.
Randomness – Varies the distribution of the spots on the granite. Lower values show more spots, higher values also make them more sparse.
Threshold – Controls the transition between the filler color and Color 1, Color 2 and Color 3.
Creases – Enables or disables crease patterns.
