Color Mode – Switches between the Temperature and Color modes of the node. Temperature – Sets the color using Kelvins when no node is connected. Active when Color Mode is set to Temperature. Color – Sets the color using a color swatch. Active when Color Mode is set to Color. Rgb Multiplier – A multiplier for the intensity of the color. Alpha – A value for the transparency. Gamma Correction – A gamma correction to be applied to the color output. |
