This page provides an overview of the V-Ray Frame Buffer, or the VFB.
The Frame Buffer automatically opens when you start a render with V-Ray.
The V-Ray Frame Buffer menu holds the main frame buffer commands. Some of the options are also available in the VFB Toolbar for quick access.
Menu | Menu Options | |
File | Save current channel – Saves the currently loaded channel to an image file format. Save all image channels to separate files – Saves all the render channels to separate files. Save all image channels to single file – Saves the image to a single multi-channel EXR or .vrimg file. Load image – Opens an image file to be previewed in the V-Ray Frame Buffer. Batch image processing – Allows processing of multiple .vrimg files with the same layer tree changes at the same time. | Batch Image Processing Input folder – Specifies a path to load images from. Output folder – Specifies a path for the output images. Layer preset – Specifies a path to a layer tree corrections preset. Output filenames suffix – Specifies the suffix added to the output image filenames. Overwrite existing – Enables overwrite of existing files with the same name in the output folder. |
Render | Start interactive rendering – Starts IPR. Abort rendering – Stops the current rendering. Render – Starts rendering. | |
Image | Follow mouse – Renders the closest buckets found to the mouse pointer, when using the bucket image sampler. If the progressive sampler is used, V-Ray samples the closest pixels to the mouse pointer. Follow mouse – Drag the mouse over the VFB while rendering to change what part of the image is sampled first; Copy current channel to clipboard – Copies the current channel to the clipboard. It can then be pasted wherever you need. Clear image – Clears the contents of the frame buffer. This is useful when starting a new render to prevent confusion with the previous image. | |
View | Display color space –Specifies the color space, in which the image is displayed. None – Does not specify a color space; Zoom VFB – Zooms in/out the rendered image in the VFB. Zoom 50% – Zooms out to 50%; Channels – Chooses which channels to see. View red channel – Displays the red channel; Color clamping – Opens the color clamping submenu options: Force color clamping – Forces color clamping; Use pixel aspect – Enables visualization of the pixel aspect ratio. Flip – Mirrors the image in the VFB. This is a view only option, the flipped image cannot be exported. This function is only active while holding the menu button or the hotkey for the corresponding type of flip. The effect does not interrupt interactive rendering. Flip horizontally – Mirrors the image horizontally. Flip vertically – Mirrors the image vertically. Panorama View – Shows the image in 360° view. Show History – Shows the History panel. Show Layers – Shows the Layers panel. | |
Options | VFB settings – Opens the VFB Settings window where you can adjusts settings for Render View, Render Region, History and Layers. |
This dropdown gives access to render channels rendered for the scene. The selected render channel is displayed in the VFB. By default, the RGB color and Alpha render channels are available. Any additional render channels that have been added to the scene also appear in the drop-down. | ||
Displays the red channel. | ||
Displays the green channel. | ||
Displays the blue channel. | ||
Displays the Alpha channel. | ||
Saves the image to disk. Press and hold the icon to bring up the submenu: Save current channel – Saves the current channel to an image file format; | ||
Clears the contents of the frame buffer. This is useful when starting a new render to prevent confusion with the previous image. | ||
Renders the closest buckets found to the mouse pointer, when using the bucket image sampler. If the progressive sampler is used, V-Ray samples the closest pixels to the mouse pointer. With this option enabled, you can right-click on the image and select Lock bucket starting point to lock the bucket (or sampling) starting point. | ||
Allows you to render regions in the VFB. See the Render Region section for more information. | ||
Starts IPR. | ||
Stops the current rendering. | ||
Starts a production render. |
Locks the mouse pointer coordinates and displays information for the selected pixel. | ||
Shows corrected colors. | ||
Shows the V-Ray log. | ||
Displays the coordinates of the mouse pointer. | ||
Specifies the sampled area size. Click on the arrow to open a context menu with the available sampled area sizes: 1x1, 3x3, 5x5, and 7x7. | ||
Specifies whether color and display corrections are applied (RGB) or not (Raw) when showing the sampled pixel values at the current mouse pointer position. | ||
Displays the RGB pixel values at the current mouse pointer position before applying any color corrections. | ||
Specifies RGB values. Click on the arrow to open a context menu with the available option. None – Does not specify the RGB value. | ||
Displays the Hue, Saturation and Value of the pixel under the current mouse position when HSV is selected. | ||
Displays the HEX of the pixel under the current mouse position when Web is selected. | ||
Displays the 8-bit color palette of the pixel under the current mouse position when 8bit is selected. |
The V-Ray Frame Buffer keeps a history of previously rendered images and lists each with a number, thumbnail, and textual details in the Render history panel. Up to four images can be called from the history to be compared in the VFB (as shown in this section). History files are stored as .vrimg files in a user-specified folder. Render history settings can be configured in the VFB Settings window.
Saves the current image from the VFB to the render history. The image is placed at the top of the render history list. | |
Enables or disables image A/B vertical comparison. Select images A and B from the render history. You can switch between comparison modes by holding down on this button or by using the hotkeys. | |
Enables or disables image A/B horizontal comparison. Select images A and B from the render history. You can switch between comparison modes by holding down on this button or by using the hotkeys. | |
Enables or disables image A/B/C/D comparison. Select images A, B, C, and D from the render history. You can switch between comparison modes by holding down on this button or by using the hotkeys. | |
Loads the selected image from the render history to the VFB. | |
Removes the selected image from the render history. |
A search field where you can filter the images based on the scene paths and notes. |
The V-Ray Frame Buffer includes a suite of color corrections and image-adjusting tools. The tools are added as layers and displayed in a layer tree. You can enable or disable a particular tool using the visibility icon () to the left of its name.
For more information on using the Layers, see the Layers page.
Each layer has a context menu. Right-click to display it:
The V-Ray Frame Buffer allows monitoring of different statistics and information about your scene in the Stats panel. The exact contents of the Stats changes depending on the scene, the rendering mode (interactive vs. production, bucket vs. progressive), and others.
Right-click to display a context menu, allowing you to copy the Stats values. |
Region rendering can be used in both IPR and Production modes to isolate only part of the frame for rendering.
Saving a region to an .exr file saves only the render region and the rest of the frame is rendered black.
These options are available when Interactive rendering is enabled. They can be accessed by right-clicking anywhere in the render region.
Select Object – Directly select scene objects by clicking on them in the VFB rendering area.
Select Material – Pick a scene material from an object that is being rendered. You only need to click on that object in the VFB rendering area and the material editor opens with it.
Set Focus Point – Sets the target distance for the Depth of Field effect to the location clicked in the VFB rendering area.
These shortcuts navigate through the VFB image. You can also find them in the VFB Settings window. Please note that the VFB window must have the current focus for the shortcuts to have effect:
Mouse | Description |
Mouse wheel | Zoom in/Zoom out |
Double-click left button | Zoom to 100% |
Middle button dragging | Pan (hand tool) |
Ctrl+Shift+Left click | Zoom in the rendered image |
Ctrl+Shift+Right click | Zoom out the rendered image |
Keyboard | Description |
Ctrl+Shift+left click, + / = | Zoom in |
Ctrl+Shift+right click, -/_ | Zoom out |
Double click, * | Zoom to 100% |
Arrow keys | Pan left, up, right, down |
F | Fit region or whole image in the VFB |
Esc | Abort render |
Q | Set history A/B vertical compare mode |
W | Set history A/B horizontal compare mode |
E | Enable history A/B/C/D compare mode |
1-9 | Load the respective image from the VFB history |
H | Show/hide history |
Ctrl+L | Show/hide the whole right panel |
P | Show/hide only layers of tree |
L | Locks the mouse pointer coordinates and displays information for the selected pixel, i.e. activates the Lock pixel info coordinates button. |
