To set a normal map, copy and paste the tiledimage and geompropvalue nodes again. Then, create a normalmap node. Connect the output of the tiledimage node to the slot of the normalmap node. Set the tiledimage's Type Node to vector3. The vector3 Node Type is used for reading normal maps. If the node types of the connected output and input differ, the LookdevX Graph Editor issues a warning. |
Connect the output of the normalmap node to the normal input slot of the standard_surface node. The LookdevX Graph Editor issues a warning that the normalmap requires a tangent reader connection. |
