Finite dome is a new utility that allows you to properly project your HDRI. If you receive a project without any exterior and you're wondering what type of environment to put it in. You can use a dome light with an HDRI. This way you can easily add a 360 degree projection image of an exterior instead of manually creating one. Or you can capture your own 360 degree image of a real world plot and use it as an environment for your project.
