This page provides information on the Bounding Box Scattering options in Chaos Scatter in Maya.
Bounding Box Scattering Parameters
The options in this rollout are active when the scattering mode is set to 3D - In bounding box.
Count – Defines an exact number of instances to scatter - either overall, or per a volume in the case of scattering defined by density (Per Cube). The number is always limited by the Instance Count Limit option.
Per Cube – When enabled, the number of instances to scatter is defined by density (Count per cube having the given edge length). The number of instances is always limited by the Instance Count Limit.
Cube Size – Specifies the edge length of the cube defining a volume for computing scattering density (Count, Per Cube). The length is measured in world units.
Examples: Count and Per Cubе
In this example Count various values are compared to when Count is used in a cubic volume (Per Cube).
01_Scatter_BBoxScattering_InstancesCount_40
Count = 40
04_Scatter_BBoxScattering_InstancesCount_5000
Count = 5000
01_Scatter_BBoxScattering_InstancesCount_1000_PCV_125
Count = 1000; Per Cube = 125
02_Scatter_BBoxScattering_InstancesCount_1000_PCV_250
Count = 1000; Per Cubе = 250
