These pages provide information on how to get Chaos Anima up and running.
Before Installation
System Requirements
Check if your hardware matches the minimum requirements to run Anima.
License Agreements and Copyrights
Check detailed licensing and copyright information related to Chaos Anima.
Installation
First Steps
Learn how to install Chaos Anima.
Licensing
Chaos License Quick Start Guide
See how to activate your Chaos License once you've installed Anima.
Cloud Floating Licensing
Cloud-based Floating Licensing allows you and your team to use a shared pool of Floating licenses entirely through the Cloud.
After Installation
Load Anima
See how to launch Anima Designer and the plugin(s) in the host app.
Trial
Free Trial
If you are a trial user, check how to download and install Chaos Anima.
