Change Direction – Click this button to change the direction of the escalator. You can also click the arrow on the escalator model to swap the direction. Incline Presets – Allow you to quickly select from many standard inclines for escalators.Just click one of these buttons to set the escalators to the angle shown in the preview. Motion Clip / Category – Used to assign a Motion Clip or Motion Category to the area.
Speed – Change the speed of the escalator. Smaller values are faster, larger values are slower. Incline – Used this parameter to manually enter the angle of the escalator or walkway. Anything below 14 degrees turns the object into a moving walkway, angles of 14 degrees or greater will create an escalator. Width – This value controls the step width of the escalator. By default it is set at 600 mm. Transform – Use the Transform parameters to change the Translation and Rotation of the escalator object. Alternatively you can use the selection tool in the 3d viewport. |
