5. Each character has 18 helper dummies located at the most common joints like hips, chest, shoulders, neck, head, elbows, wrists, ankles, and toes. Also, it is possible to link multiple objects to the same character or linking point. 6. Select the 3d object that you want to link to the character and use click on the Align tool to match the position and rotation of the helper dummy. Then click on the helper dummy to align the two objects. 7. An align dialogue window will appear with several options to choose from. Align Position aligns the 3D objects in world space and Align Orientation aligns the rotation in local space. Select the options that best suit your needs and click OK to commit. |
