This page provides information on the V-Ray GPU Engine Select rollout under the V-Ray GPU Settings tab.
UI Path: ||Render Setup window|| >  Settings tab > V-Ray GPU Engine Select rollout (Renderer set to V-Ray GPU)
Max2024_VRay7Beta_GPUSetting_EngineSelect
RTX – Changes V-Ray GPU rendering engine to RTX.
This option does not work if there are no GPU devices available.
Max2024_VRay7Beta_GPU_Setting_DeviceSelect
