/// Oiginal notice:
* srdnoise23, Simplex noise with rotating gradients
* and a true analytic derivative in 2D and 3D.
* This is version 2 of srdnoise23 written in early 2008.
* A stupid bug was corrected. Do not use earlier versions.
* Author: Stefan Gustavson, 2003-2008
* Contact: stefan.gustavson@gmail.com
* This code was GPL licensed until February 2011.
* As the original author of this code, I hereby
* release it into the public domain.
* Please feel free to use it for whatever you want.
* Credit is appreciated where appropriate, and I also
* appreciate being told where this code finds any use,
* but you may do as you like.
/// Translated and modified by Ivan Mavrov, Chaos Group Ltd. 2016
/// Contact: ivan.mavrov@chaosgroup.com
/// 3D Simplex flow noise implementation.
/// Returned values are in the [0, 1] range.
float simplexFlowNoise3D(point position, float flow, output vector dNoise) {
int perm[512] = {
151,160,137,91,90,15,
131,13,201,95,96,53,194,233,7,225,140,36,103,30,69,142,8,99,37,240,21,10,23,
190, 6,148,247,120,234,75,0,26,197,62,94,252,219,203,117,35,11,32,57,177,33,
88,237,149,56,87,174,20,125,136,171,168, 68,175,74,165,71,134,139,48,27,166,
77,146,158,231,83,111,229,122,60,211,133,230,220,105,92,41,55,46,245,40,244,
102,143,54, 65,25,63,161, 1,216,80,73,209,76,132,187,208, 89,18,169,200,196,
135,130,116,188,159,86,164,100,109,198,173,186, 3,64,52,217,226,250,124,123,
5,202,38,147,118,126,255,82,85,212,207,206,59,227,47,16,58,17,182,189,28,42,
223,183,170,213,119,248,152, 2,44,154,163, 70,221,153,101,155,167, 43,172,9,
129,22,39,253, 19,98,108,110,79,113,224,232,178,185, 112,104,218,246,97,228,
251,34,242,193,238,210,144,12,191,179,162,241, 81,51,145,235,249,14,239,107,
49,192,214, 31,181,199,106,157,184, 84,204,176,115,121,50,45,127, 4,150,254,
138,236,205,93,222,114,67,29,24,72,243,141,128,195,78,66,215,61,156,180,
// Gradient component that leads to a vector of length sqrt(2).
// float a = sqrt(2)/sqrt(3);
float a = 0.81649658;
vector gradientUBase[16] = {
vector( 1.0, 0.0, 1.0), vector( 0.0, 1.0, 1.0),
vector(-1.0, 0.0, 1.0), vector( 0.0, -1.0, 1.0),
vector( 1.0, 0.0, -1.0), vector( 0.0, 1.0, -1.0),
vector(-1.0, 0.0, -1.0), vector( 0.0, -1.0, -1.0),
vector( a, a, a), vector(-a, a, -a),
vector(-a, -a, a), vector( a, -a, -a),
vector(-a, a, a), vector( a, -a, a),
vector( a, -a, -a), vector(-a, a, -a)
vector gradientVBase[16] = {
vector(-a, a, a), vector(-a, -a, a),
vector( a, -a, a), vector( a, a, a),
vector(-a, -a, -a), vector( a, -a, -a),
vector( a, a, -a), vector(-a, a, -a),
vector( 1.0, -1.0, 0.0), vector( 1.0, 1.0, 0.0),
vector(-1.0, 1.0, 0.0), vector(-1.0, -1.0, 0.0),
vector( 1.0, 0.0, 1.0), vector(-1.0, 0.0, 1.0),
vector( 0.0, 1.0, -1.0), vector( 0.0, -1.0, -1.0)
// Helper function to compute the rotated gradient.
vector getGradient(int index, float sinTheta, float cosTheta) {
int safeIndex = index % 16;
vector gradientU = gradientUBase[safeIndex];
vector gradientV = gradientVBase[safeIndex];
return cosTheta * gradientU + sinTheta * gradientV;
// Skewing factors for the 3D simplex grid.
// float F3 = 1.0 / 3.0;
// float G3 = 1.0 / 6.0;
float F3 = 0.333333333;
float G3 = 0.166666667;
float G3a = 2.0 * G3;
float G3b = 3.0 * G3 - 1.0;
// Skew the input space to determine the simplex cell we are in.
float skew = (position[0] + position[1] + position[2]) * F3;
point skewedPosition = position + skew;
point skewedCellOrigin = floor(skewedPosition);
// Unskew the cell origin
float unskew = (skewedCellOrigin[0] + skewedCellOrigin[1] + skewedCellOrigin[2]) * G3;
point cellOrigin = skewedCellOrigin - unskew;
// The offset from the cell's origin a.k.a point 0
vector offset0 = position - cellOrigin;
// The second point offset from the cell origin in skewed space.
vector skewedOffset1;
// The third point offset from the cell origin in skewed space.
vector skewedOffset2;
if (offset0[0] >= offset0[1]) {
if (offset0[1] >= offset0[2]) {
// X Y Z order
skewedOffset1 = vector(1, 0, 0);
skewedOffset2 = vector(1, 1, 0);
} else if (offset0[0] >= offset0[2]) {
// X Z Y order
skewedOffset2 = vector(1, 0, 1);
} else {
// Z X Y order
skewedOffset1 = vector(0, 0, 1);
} else {
if (offset0[1] < offset0[2]) {
// Z Y X order
skewedOffset2 = vector(0, 1, 1);
} else if (offset0[0] < offset0[2]) {
// Y Z X order
skewedOffset1 = vector(0, 1, 0);
} else {
// Y X Z order
// A step of (1, 0, 0) in skewed space means a step of (1 - G3, -G3, -G3) in regular space.
// A step of (0, 1, 0) in skewed space means a step of (-G3, 1 - G3, -G3) in regular space.
// A step of (0, 0, 1) in skewed space means a step of (-G3, -G3, 1 - G3) in regular space.
// The offset from point 1 in regular space.
vector offset1 = offset0 - skewedOffset1 + G3;
// The offset from point 2 in regular space.
vector offset2 = offset0 - skewedOffset2 + G3a;
// The offset from point 3 in regular space.
vector offset3 = offset0 + G3b;
// Wrap the integer indices at 256, to avoid indexing perm[] out of bounds.
int i = int(skewedCellOrigin[0]) & 255;
int j = int(skewedCellOrigin[1]) & 255;
int k = int(skewedCellOrigin[2]) & 255;
// Sine and cosine for the gradient rotation angle.
float sinTheta = 0.0;
float cosTheta = 0.0;
sincos(M_2PI * flow, sinTheta, cosTheta);
// Calculate the contribution from the four points.
float t0 = 0.6 - dot(offset0, offset0);
float t02 = 0.0;
float t04 = 0.0;
vector gradient0 = vector(0.0);
float n0 = 0.0;
if (t0 < 0.0) {
t0 = 0.0;
} else {
t02 = t0 * t0;
t04 = t02 * t02;
gradient0 = getGradient(perm[i + perm[j + perm[k]]], sinTheta, cosTheta);
n0 = t04 * dot(gradient0, offset0);
float t1 = 0.6 - dot(offset1, offset1);
float t12 = 0.0;
float t14 = 0.0;
vector gradient1 = vector(0.0);
float n1 = 0.0;
if (t1 < 0.0) {
t1 = 0.0;
} else {
t12 = t1 * t1;
t14 = t12 * t12;
gradient1 = getGradient(perm[i + int(skewedOffset1[0]) + perm[j + int(skewedOffset1[1]) + perm[k + int(skewedOffset1[2])]]], sinTheta, cosTheta);
n1 = t14 * dot(gradient1, offset1);
float t2 = 0.6 - dot(offset2, offset2);
float t22 = 0.0;
float t24 = 0.0;
vector gradient2 = vector(0.0);
float n2 = 0.0;
if(t2 < 0.0) {
t2 = 0.0;
} else {
t22 = t2 * t2;
t24 = t22 * t22;
gradient2 = getGradient(perm[i + int(skewedOffset2[0]) + perm[j + int(skewedOffset2[1]) + perm[k + int(skewedOffset2[2])]]], sinTheta, cosTheta);
n2 = t24 * dot(gradient2, offset2);
float t3 = 0.6 - dot(offset3, offset3);
float t32 = 0.0;
float t34 = 0.0;
vector gradient3 = vector(0.0);
float n3 = 0.0;
if(t3 < 0.0) {
t32 = 0.0;
} else {
t32 = t3 * t3;
t34 = t32 * t32;
gradient3 = getGradient(perm[i + 1 + perm[j + 1 + perm[k + 1]]], sinTheta, cosTheta);
n3 = t34 * dot(gradient3, offset3);
// Accumulate the contributions from each point to get the final noise value.
// The result is scaled to return values in the range [-1,1].
float noiseValue = 32.0 * (n0 + n1 + n2 + n3);
// Compute noise derivative.
// *dnoise_dx = -8.0f * t02 * t0 * x0 * dot(gx0, gy0, gz0, x0, y0, z0) + t04 * gx0;
// *dnoise_dy = -8.0f * t02 * t0 * y0 * dot(gx0, gy0, gz0, x0, y0, z0) + t04 * gy0;
// *dnoise_dz = -8.0f * t02 * t0 * z0 * dot(gx0, gy0, gz0, x0, y0, z0) + t04 * gz0;
// *dnoise_dx += -8.0f * t12 * t1 * x1 * dot(gx1, gy1, gz1, x1, y1, z1) + t14 * gx1;
// *dnoise_dy += -8.0f * t12 * t1 * y1 * dot(gx1, gy1, gz1, x1, y1, z1) + t14 * gy1;
// *dnoise_dz += -8.0f * t12 * t1 * z1 * dot(gx1, gy1, gz1, x1, y1, z1) + t14 * gz1;
// *dnoise_dx += -8.0f * t22 * t2 * x2 * dot(gx2, gy2, gz2, x2, y2, z2) + t24 * gx2;
// *dnoise_dy += -8.0f * t22 * t2 * y2 * dot(gx2, gy2, gz2, x2, y2, z2) + t24 * gy2;
// *dnoise_dz += -8.0f * t22 * t2 * z2 * dot(gx2, gy2, gz2, x2, y2, z2) + t24 * gz2;
// *dnoise_dx += -8.0f * t32 * t3 * x3 * dot(gx3, gy3, gz3, x3, y3, z3) + t34 * gx3;
// *dnoise_dy += -8.0f * t32 * t3 * y3 * dot(gx3, gy3, gz3, x3, y3, z3) + t34 * gy3;
// *dnoise_dz += -8.0f * t32 * t3 * z3 * dot(gx3, gy3, gz3, x3, y3, z3) + t34 * gz3;
dNoise = t02 * t0 * offset0 * dot(gradient0, offset0) + t04 * gradient0;
dNoise += t12 * t1 * offset1 * dot(gradient1, offset1) + t14 * gradient1;
dNoise += t22 * t2 * offset2 * dot(gradient2, offset2) + t24 * gradient2;
dNoise += t32 * t3 * offset3 * dot(gradient3, offset3) + t34 * gradient3;
dNoise *= -8.0;
// Scale noise derivative to match the noise scaling.
//dNoise *= (32.0 / 2.0);
// Scale to the [0, 1] range.
return 0.5 * noiseValue + 0.5;
/// 3D Fractal Simplex flow noise implementation.
/// Returned values are in the [-1, 1] range.
float fractalSimplexFlowNoise3D(
point position,
float flow,
float lacunarity,
float flowRate,
float gain,
float advect,
int octaveCount
float noiseValue = 0.0;
float flowValue = flow;
float amplitude = 1.0;
float advectionAmount = advect;
for (int octave = 0; octave < octaveCount; ++octave) {
vector flownoise3DGradient = vector(0.0);
float noiseOctave = amplitude * (simplexFlowNoise3D(position, flowValue, flownoise3DGradient) - 0.5);
noiseValue += noiseOctave;
position -= advectionAmount * noiseOctave * flownoise3DGradient;
position *= lacunarity;
flowValue *= flowRate;
amplitude *= gain;
advectionAmount *= advect;
return noiseValue;
shader FractalSimplexFlowNoise
[[ string description = "Fractal Simplex flow noise" ]]
float start_frequency = 1.0
[[ string description = "Initial sampling position multiplier that affects the overall granularity." ]],
vector start_offset = vector(0.0)
[[ string description = "Offsets the initial sampling position effectively shifting the pattern in the specified direction." ]],
float flow = 1.0
[[ string description = "The coordinate of a special noise dimension with a period of 1 that naturally evolves the noise to animate it instead of sliding a 3D slice throught the noise space." ]],
float lacunarity = 2.0
[[ string description = "Position (frequency) multiplier per iteration." ]],
float flow_rate = 1.0
[[ string description = "Flow coordinate multiplier per iteration." ]],
float gain = 0.5
[[ string description = "Amplitude multiplier per iteration." ]],
float advect = 0.5
[[ string description = "Both initial advection amount and advection multiplier per iteration." ]],
int octaves = 8
[[ string description = "Number of fractal iterations." ]],
float attenuation = 1.0
[[ string description = "The power of the falloff applied to the final result." ]],
output color result = 0.0
point objectPosition = transform("object", P);
point startPosition = start_frequency * objectPosition - start_offset;
float noiseValue = fractalSimplexFlowNoise3D(startPosition, flow, lacunarity, flow_rate, gain, advect, octaves);
noiseValue = 0.5 * noiseValue + 0.5;
noiseValue = pow(noiseValue, attenuation);
result = color(noiseValue);
