The following parameters are located in the Details right-hand side panel and are available upon selection of any Scatter object from the Objects left-hand side panel. – A showing the type and name of the selected element, allowing you also to rename the element. The new name is automatically displayed in the respective Object tab.
– Toggles the visibility of the element on and off. Invisible objects are indicated by .
– Selects parent and all children. – Selects the parent element. – Selects all children elements. – Makes instance unique. – Selects all instances. – Saves Scatter preset. Layers – Adds a new layer.
– Removes the selected layer.
Density – Max angle to up vector – Detect collisions – Models – – Removes a model. TargetsExclusion Areas |
