Color Management Setup
For HDR output (recommended): - Enable HDR in Windows (Display Settings > Use HDR). This is optional, and it depends on the LED processors, as they usually have their own options.
- Enable HDR in the LED processors, if needed (possible options are HDR/HDR10 format, PQ/ST2084 transfer function/gamma/EOTF, Rec.2020/Rec.2100/BT.2020/BT.2100 color space/gamut).
For normal SDR sRGB output: - Disable HDR in Windows (Display Settings > Use HDR).
- Set up sRGB input in the LED processors (Rec.709/BT.709/sRGB color space/gamut, sRGB transfer function).
