This page provides information about the supported .vrscene features exported from Cinema 4D.
UI Category | Native name | V-Ray plugin name (plugin/parameter) | Support |
Light | |||
Basic | Viewport Visibility | - | |
Render Visibility | - | ||
Enabled | - | ||
Coordinates | Coordinates | transform | |
General | Color | color | |
Use Temperature | - | ||
Color Temperature | color | ||
Intensity | intensity | ||
Type: Omni Spot Infinite Area IES | LightOmni LightSpot LightDirect / SunLight(with Sun tag) LightRectangle LightIES | ||
Shadow: None Shadow Maps (Soft) Raytraced (Hard) Area | - - - - | ||
Visible Light: None Visible Volumetric Inverse Volumetric | - - - - | ||
No Illumination | - | ||
Ambient Illumination | - | ||
Diffuse | - | ||
Specular | - | ||
GI Illumination | - | ||
Show Illumination | - | ||
Show Visible Light | - | ||
Show Clipping | - | ||
Separate Pass | - | ||
Export to Compositing | - | ||
Details | - | ||
Use Gradient | |||
Color | |||
Load Preset | |||
Save Preset | |||
Near Clip | |||
Far Clip | |||
Area Shape: Disc Rectangle Line Sphere Cylinder Cylinder (Perpendicular) Cube Hemisphere Object/Spline | |||
Object | |||
Size X | |||
Size Y | |||
Size Z | |||
Falloff Angle | |||
Samples | |||
Add Grain (Slow) | |||
Show in Render | |||
Show as Solid in Viewport | |||
Show in Specular | |||
Show in Reflection | |||
Visibility | Use Falloff | - | |
Shadow | Shadow: None Shadow Maps (Soft) Raytraced (Hard) Area | - | |
Resolution Y | |||
Sample Radius | |||
Sample Radius Boost: None Low (2x) Medium (4x) High (8x) | |||
Absolute Bias | |||
Bias (Rel) | |||
Bias (Abs) | |||
Parallel Width | |||
Outline Shadow | |||
High Quality | |||
Shadow Cone | |||
Angle | |||
Soft Cone | |||
Photometric | Photometric Intensity | - | |
Intensity | |||
Unites: Candela Lumen | |||
Photometric Data | |||
Path | |||
Photometric Size | |||
Caustics | Surface Caustics | - | |
Noise | - | ||
Lens | - | ||
Project | - | ||
Sun | Time | - | |
Interpolate Time | - | ||
Interpolate Date | - | ||
Latitude | - | ||
Longitude | - | ||
Distance | - | ||
Set Light Color | - |
