This page provides information about the supported .vrscene features exported from V-Ray for Cinema 4D.
 Chaos Arena has better support for .vrscene files exported from V-Ray Next and later. It is recommend to use the latest officially released V-Ray version.
Lights
Rectangle Light (LightRectangle)
UI CategoryNative parameter nameV-Ray plugin name (plugin/parameter)Support
Basic
Namescene_name(tick)
Viewport Visibility-(minus)
Renderer Visibility-(tick)
Enabled-(tick)
CoordinatesCoordinatestransform(tick)
GeneralEnabledenabled(tick)
Colorcolor(tick)
Intensityintensity(tick)
Unitsunits(tick)
Disk Shapeis_disc(tick)
Width
Height
U Sizeu_size(tick)
V Sizev_size(tick)
Directionaldirectional(tick)
TextureUse Textureuse_rect_tex(tick)
Rect Texrect_tex(tick)
OptionsInvisibleinvisible(tick)
Occlude Other LightsoccludeLights(error)
Double SideddoubleSided(tick)
Affect DiffuseaffectDiffuse(tick)
Affect SpecularaffectSpecular(tick)
Affect ReflectionsaffectReflections(tick)
Affect AtmosphericsaffectAtmospherics
Diffuse Contributiondiffuse_contribution(tick)
Specular Contributionspecular_contribution(tick)
Atmospherics Contributionatmospherics_contribution
Cut-off ThresholdcutoffThreshold(error)
Texture Resolutiontex_resolution(error)
Near Decay On
Near Decay Start
Near Decay End
Far Decay On
Far Decay Start
Far Decay End
ShadowsShadowsshadows(tick)
Shadow BiasshadowBias(tick)
Shadow ColorshadowColor(error)
Photon EmissionCaustics SubdivscausticSubdivs(error)
Caustics MultipliercausticMult(error)
ProjectModeSettingsLightLinker/ignored_lights(error)
Objects
(error)
Sphere Light (LightSphere)
UI CategoryNative nameV-Ray plugin name (plugin/parameter)Support
Basic
Enabled-(tick)
Colorcolor(tick)
Unitsunits(tick)
Radiusradius(tick)
Sphere Segmentssphere_segments(error)
Nera Decay On
Near Decay Start
Near Decay End
Far Decay On
Far Decay Start
Far Decay End
Objects
(error)
Dome Light (LightDome)
Basic
Enabled-(tick)
Colorcolor(tick)
Dome Sphericaldome_spherical(error)
Dome Adaptivedome_adaptive(error)
Dome Finite
Finite Radius
Projection Height
Finite Ground Blend
TextureUse Textureuse_dome_tex(tick)
Dome Texdome_tex(tick)
OptionsInvisibleinvisible(error)
Affect DiffuseaffectDiffuse(error)
Affect SpecularaffectSpecular(error)
Affect ReflectionsaffectReflections(error)
Affect Alpha
Diffuse Contributiondiffuse_contribution(error)
Specular Contributionspecular_contribution(error)
ShadowsShadowsshadows(error)
Shadow BiasshadowBias(error)
Photon EmissionPhoton Target Radius
Emit Distance
Objects
(error)
IES Light (LightIES)
Basic
Enabled-(tick)
Colorcolor(tick)
Ies Fileies_file(tick)
Filter Colorfilter_color(tick)
Powerpower(tick)
Override Prescribed Poweroverride_prescribed_power(tick)
Rescale Max Intensityrescale_max_intensty(tick)
New Max Intensitynew_max_intensity(tick)
OptionsAffect DiffuseaffectDiffuse(tick)
Area Speculararea_speculars(tick)
Shadow SubdivsshadowSubdivs(error)
Soft Shadows:
No
Use Light Shape for Shadows
Use Light Shape for Shadows and Illumination
soft_shadows=0
soft_shadows=1
soft_shadows=2
(tick)
(tick)
(tick)
SamplingCut-off ThresholdcutoffThreshold(error)
DecayNear Decay On
Near Decay Start
Near Decay End
Far Decay On
Far Decay Start
Far Decay End
Light ShapeIES Light Shapeies_light_shape(tick)
Widthies_light_width(tick)
Lengthies_light_length(tick)
Heighties_light_height(tick)
Diameteries_light_diameter(tick)
Objects
(error)
V-Ray Sun(SunLight)
Basic
Enabled-(tick)
General
Intensityintensity_multiplier(tick)
Sizesize_multiplier(tick)
Color Mode:
Filter
Direct
Override
color_mode=0
color_mode=1
color_mode=2
(tick)
(tick)
(tick)
Sky Model:
Preetham et al.
CIE clear
CIE overcast
Hosek et al.
PRG Clear Sky
sky_model.0
sky_model=1
sky_model=2
sky_model=3
sky_model=4
(tick)
(tick)
(tick)
(tick)
(tick)
Ground Albedoground_albedo (tick)
Horiz Illumhoriz_illum (tick)
Blend Angleblend_angle (tick)
Horizon Offsethorizon_offset (tick)
Turbidityturbidity (tick)
Ozoneozone (tick)
CloudsOnclouds_on (tick)
Ground Shadows
clouds_ground_shadows
(tick)
Densityclouds_density (tick)
Density Multiplierclouds_density_multiplier (error)
Variety clouds_variety(tick)
Cirrus Amountclouds_seed (error)
Thickness(m) clouds_cirrus_amount(tick)
Seed
clouds_offset_x
(tick)
Height(m)
clouds_height
(tick)
Longitude Offset (m)
clouds_offset_x
(tick)
Latitude Offset (m)clouds_offset_y (tick)
Longitude Phase (%)
clouds_phase_x
(tick)
Latitude Phase (%)clouds_phase_y (tick)
Enable Contrails
clouds_contrails_on
(error)
Number Contrails
clouds_contrails_num_planes
(error)
Contrails Strength
clouds_contrails_strength
(error)
Contrails Distortion
clouds_contrails_distortion
(error)
Contrails Offset Longitude (m)
clouds_contrails_offset_x
(error)
Contrails Offset Latitude(m)
clouds_contrails_offset_y
(error)
Contrails Timeclouds_contrails_time (error)
OptionsInvisibleaffectDiffuse(tick)
Affect AtmosphericsaffectAtmospherics (error)
Atmospherics Contributionatmospherics_contribution (error)
Shadow TextureshadowColor(error)
Atmos Shadowsatmos_shadows (error)
Photon EmissionPhoton Radiusphoton_radius (error)
Aerial Perspective
Enabled
Visibility Range (m)
Atmospheric Layer Height (m)
Inscattered Light Multiplier
Affect Environment
Affect Background
Affect Alpha
Filter Color
Primary Visibility
Objects
(error)
V-Ray Sun and Sky
Basic
Enabled-(tick)
General
Color Mode:
Filter
Direct
Override
color_mode=0
color_mode=1
color_mode=2
(tick)
(tick)
(tick)
Sky Model:
Preetham et al.
CIE clear
CIE overcast
Hosek et al.
PRG Clear Sky
sky_model.0
sky_model=1
sky_model=2
sky_model=3
sky_model=4
(tick)
(tick)
(tick)
(tick)
(tick)
Ozoneozone (tick)
Ground Shadows
(tick)
Seed
clouds_offset_x
(tick)
Height(m)
clouds_height
(tick)
clouds_offset_x
(tick)
Longitude Phase (%)
clouds_phase_x
(tick)
Enable Contrails
clouds_contrails_on
(error)
Number Contrails
(error)
Contrails Strength
(error)
(error)
(error)
(error)
Aerial Perspective
Enabled
Affect Environment
Affect Background
Affect Alpha
Filter Color
Primary Visibility
Objects
(error)
Physical Camera
Physical Camera (CameraPhysical)
Basic tag
Name-(minus)
Visible in Editor-(minus)
Visible in Renderer-(minus)
Enabled-(minus)
Coord. tagCoordinatesRenderView/transform(tick)
Physical
Camera
tag
Camera Type:
Still cam
Movie cam
Video cam
type=0
type=1
type=2
(tick)
(error)
(error)
Specify Field of Viewspecify_fov(tick)
Field of viewfov(tick)
Film Gate (mm)film_width(tick)
Focal length (mm)focal_length(tick)
Zoom factorzoom_factor(tick)
Film speed (ISO)ISO(tick)
F-Numberf_number(tick)
Shutter Speed (S^-1)shutter_speed(tick)
Shutter Angleshutter_angle
(error)
Shutter Оffsetshutter_offset
(error)
Latency (s)latency
(error)
Exposure:
No exposure
Physical exposure
Exposure value (EV)
exposure=0
exposure=1
exposure=2
(tick)
(tick)
(tick)
Exposure Valueexposure_value(tick)
Vignettingvignetting(error)
White Balancewhite_balance(tick)
Vertical Tiltlens_shift(tick)
Horizontal Tilthorizontal_shift(tick)
Vertical Shiftvertical_offset(tick)
Horizontal Shifthorizontal_offset(tick)
Depth of Field Enableduse_dof(tick)
Specify Focusspecify_focus(tick)
Focus Distancefocus_distance(tick)
Aperture Shapeblades_enable(tick)
Blades Numberblades_num(tick)
Rotationblades_rotation(tick)
Center Biascenter_bias(tick)
Anisotropyanisotropy(tick)
Optical Vignettingoptical_vignetting
(error)
Bitmap Aperture Enabledbmpaperture_enable
(error)
Filebmpaperture_tex
(error)
Bitmap Resolutionbmpaperture_resolution
(error)
Affect Exposurebmpaperture_affects_exposure
(error)
Motion Blur Enableduse_moblur
(error)
Rolling Shutter Mode:
Disabled
Top to bottom
Bottom to top
Left to right
Right to left
rolling_shutter_mode=0
rolling_shutter_mode=1
rolling_shutter_mode=2
rolling_shutter_mode=3
rolling_shutter_mode=4
(error)
(error)
(error)
(error)
(error)
Duration (s^-1)rolling_shutter_duration
(error)
Distortion Type:
Quadratic
Cubic
Lens file
Texture
distortion_type=0
distortion_type=1
distortion_type=2
distortion_type=3
(error)
(error)
(error)
(error)
Amountdistortion
(error)
Distortion Texturedistortion_tex
(error)
Mix StrengthTexAColorOp/mult_a
(error)
Lens Filelens_file
(error)
Geometry
Native NameV-Ray Plugin NameSupport
V-Ray Clipper
VRayClipper
(error)
V-Ray DecalVRayDecal(tick)
V-Ray EnmeshGeomEnmesh(error)
V-Ray Fur
GeomHair
(tick)
V-Ray Particles
(error)
V-Ray Proxy
GeomMeshFile
(tick)
V-Ray SceneVRayScene
(tick)
Geometry tag
GeomDisplacedMesh
GeomStaticSmoothedMesh
(tick)
(tick)
Object Properties tag
Renderable Spline tag
Environment
VRayEnvironmentFog
(tick)
Materials
Classic MaterialsAL Surface MaterialBRDFALSurface
  • Diffuse
  • Diffuse strength
  • Reflect color
  • Reflect strength
  • Reflect roughness
  • Reflect IOR
  • Reflect distribution GGX
Blend MaterialBRDFLayered
  • Base material
  • Coat materials
  • Blend amount
  • Blend amount texture
  • Opacity
Bump Material
BRDFBump
  • Base material
  • Bump map
  • Bump amount
Car Paint 2 MaterialBRDFCarPaint2
  • Base color
  • Base reflection
  • Base glossiness
  • Base glossiness tail
  • Coat color
  • Coat amount
  • Coat ior
  • Coat glossiness
Fast SSS2 MaterialBRDFSSS2Complex
  • IOR
  • Subsurface color
  • Specular color
  • Specular amount
  • Specular glossiness
Hair Next MaterialBRDFHair4
  • Melanin
  • Pheomelanin
  • Dye color
  • Diffuse color
  • Gossiness
  • Primary grlossiness
  • Softness
  • Highlight shift
  • IOR
  • Glint
  • Gray hair density
  • Randomizations
  • Primary tint
    Secondary tint
  • Transmission tint
Light Material
BRDFLight
  • Color
  • Color multiplier
  • Direct Illumination On
Scanned MaterialBRDFScanned(error)
Stochastic Flakes
BRDFStochasticFlakes
  • Highlight glossiness
  • Reflection filter
  • BRDF Type: GGX
2Sided MaterialMtl2Sided
  • Front Material
  • Back Material
  • Translucency
Toon Material
Override Material
Node MaterialsAl Surface Node Material
Blend Node Material
Bump Node Material
V-Ray Node Material
Car Pain 2 Node Material
Fast SSS 2 Node Material
Hair Next Node Material
Light Node Material
Toon Node Material
Two Sided Node Material
Override Node Material
VRayMtl
Native nameV-Ray plugin Name (plugin/parameter)Support
VRayMtlBRDFVRayMtl
Diffuse
Diffuse Color
diffuse
(tick)
Diffuse Color Texturediffuse
(tick)
Mix. Strength
TexCombineColor / texture_multiplier
(tick)
Diffuse Roughnessroughness
(error)
Roughness Textureroughness
(error)
Opacity Source:
Default
Alpha from Texture
Alpha from Diffuse
opacity_mode=0
opacity_mode=1
opacity_mode=2
(error)
(tick)
(error)
Opacity Color
Opacity Color Texture
Mix. Strength
(tick)
Self-Illumination Colorself_illumination(tick)
Brightness
Self-Illumination Color Textureself_illumination(tick)
Mix Strength
TexCombineColor / result_multiplier
(tick)
Mix Type:
Normal
Add
Substract
Multiply
Self-Illumination Affect GIself_illumination_gi(tick)
Compensate Camera Exposurecompensate_camera_exposure(error)
Reflection
BRDF Type:
GGX
Phong
Blinn
Ward
brdf_type=
brdf_type=
brdf_type=
brdf_type=
(tick)
(tick)
(tick)
(tick)
Colorreflect(tick)
Texturereflect(tick)
Mix Strength
(tick)
Glossinessreflect_glossiness(tick)
Texturereflect_glossiness(tick)
Mix StrengthTexCombineColor / texture_multiplier(tick)
GGX Tail Falloffgtr_gamma(tick)
Texturegtr_gamma(error)
Mix Type:
Normal
Add
Substract
Multiply
Metalnessmetalness(tick)
Texturemetalness(tick)
Mix Strength
(error)
GTR Energy Compensation
Use Roughnessoption_use_roughness(tick)
Use Bump to Glossiness
Fresnel Reflectionsfresnel(tick)
Lock Fresnel IORfresnel_ior_lock(tick)
Fresnel IORfresnel_ior(tick)
Texture
fresnel_ior(tick)
Mix Type
Anisotropy (-1..1)anisotropy(error)
Anisotropy Textureanisotropy(error)
Mix StrengthTexCombineColor / texture_multiplier(error)
Anisotropy Rotationanisotropy_rotation(error)
Anisotropy Rotation Textureanisotropy_rotation(error)
UV Vectors Derivation:
Local object Axis
UV Space
Anisotropy Axisanisotropy_axis(error)
Enable Thin Film
Thickness Min (nm)
Thickness Max (nm)
Thickness Blend
Thin Film IOR
Texture
Mix Strength
Mix Type
Trace Reflectionsreflect_trace(error)
Max depthreflect_depth(error)
Enable Dim Distancereflect_dim_distance(error)
Dim Fall-offreflect_dim_distance_falloff(error)
Reflect on Back Sideoption_reflect_on_back(tick)
Soften
Affect Channels:
Color Only
Color+alpha
All channels
reflect_affect_alpha=0
reflect_affect_alpha=1
reflect_affect_alpha=2
(error)
(error)
(error)
CoatCoat Colorcoat_color(tick)
Texture coat_color(tick)
Coat Amountcoat_amount(tick)
Coat Amount Texturecoat_amount(tick)
Coat Glossinesscoat_glossiness(tick)
Coat Glossiness Texturecoat_glossiness(tick)
Coat IORcoat_ior(tick)
Coat IOR Texturecoat_ior(tick)
Coat Bump Lockcoat_bump_lock(tick)
Coat Bump Mapcoat_bump_map(error)
Coat Bump Amountcoat_bump_amount(error)
Coat Bump Type:
Bump Map
Normal map in tangent space
Normal map in object space
Normal map in screen space
Normal map in world space
From texture bump output
Explicit
Refraction
Colorrefract
(tick)
Texturerefract(tick)
Refraction Glossinessrefract_glossiness(tick)
Texture refract_glossiness(tick)
Refraction IORrefract_ior(tick)
Refraction IOR Texturerefract_ior(tick)
Affect Shadowsrefract_affect_shadows(tick)
Refract Thin Walledrefract_thin_walled(tick)
Translucency Type:
None
Volumetric
SSS
translucency=0
translucency=5
translucency=6
(error)
(error)
(error)
Illumination Method:
Directional
Uniform
Fog Color / Scatter Radiusfog_color(tick)
Fog Color TextureTexCombineColor / texture_multiplier(error)
Depth (cm)/Scale (cm)fog_mult(tick)
SSS Amount
translucency_amount
(error)
Scatter Colortranslucency_color(error)
Scatter Color Texture translucency_color(error)
SSS color
Trace Refractionsrefract_trace(error)
Max Depthrefract_depth(error)
Affect Alpha:
Color Only
Color+alpha
All channels
refract_affect_alpha=0
refract_affect_alpha=1
refract_affect_alpha=2
(error)
(error)
(error)
Enable Dispersiondispersion(error)
Aberration
SheenSheen Colorsheen_color(error)
Texture sheen_color(error)
Sheen Glossinesssheen_glossiness(error)
Sheen Glossiness Texturesheen_glossiness(error)
Bump
Enable Bump map-(tick)
Bump Amountbump_amount
(tick)
Bump Texturebump_tex
(tick)
Bump Type:
Bump map
Normal Map in Tangent Space
Normal Map in Object Space
Normal Map in Screen Space
Normal Map in World Space
From Texture Bump Output
Explicit Normal
OptionsMaterial Id EnabledMtlMaterialID / material_id_number(error)
Material IDMtlMaterialID / material_id_number(error)
Multimatte ID
Round Edges Enabled
(tick)
Radius
Consider Same Object Only
Corners:
Covex and Concave
Convex Only
Concave Only
Cutoff option_cutoff(error)
Double-sidedoption_double_sided(tick)
Fix Dark Edges
Abbe numberdispersion
(error)
MultTexCombineColor / result_multiplier
(tick)
Map channelanisotropy_derivation
(error)
Env. priorityenvironment_priority
(error)
Glossy Fresneloption_glossy_fresnel
(tick)
Preserve energy:
RGB
Monochrome
option_energy_mode=0
option_energy_mode=1
(error)
(error)
Use irradiance mapoption_use_irradiance_map
(error)
Fog system units scalingfog_unit_scale_on
(error)
Displace Texture MultiplierTexCombineColor / texture_multiplier
(error)
GTR falloff Texture MultiplierTexCombineColor / texture_multiplier
(error)
IOR Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Translucent Texture MultiplierTexCombineColor / texture_multiplier
(error)
Environment TextureBRDFVRayMtl / environment_override
Maps
Native NameV-Ray plugin NameSupport
V-Ray Maps
Classic Textures
VRayBitmapTexBitmap(tick)
VRayC4DBakeRawBitmapBuffer(tick)
VRayCurvatureTexCurvature(error)
VRayDirtTexDirt(error)
VRayDistanceTexDistance(error)
VRayEdges
(tick)
VRayFalloffTexFalloff(tick)
VRayFresnelTexFresnel(tick)
VRayHairSampler
VRayLayeredTexLayeredMax(tick)
VRayMix
TexBitmap(tick)
VRayMultiSubTexTexMulti(tick)
VRayNormalMapTexNormalBump
(tick)
VRayOCIO
VRayRampTexRamp(tick)
VRaySamplerInfo
VRaySkyTexSky(tick)
VRaySoftbox
VRayTriplanarTexTexTriplanarPARTIAL
(Except Texture Mode - Different Texture on Each Axis in Each Direction)
VRayUVWChannel
VRayUVWRandomizerTexUVWRandomizer(tick)
VRayUserColor
VRayUserInteger
VRayUserScalar
Node Textures
Bitmap
Bump to Glossiness
Cellular
Checker
Color Arithmetic
Color Channel
Color Correction
Color Node
Color Range
Color to Float
Combine Color
Combine Float
Compose Color
Curvature
Dirt
Distance
Edges
Falloff
Float Arithmetic
Float to Color
Fresnel
Hair Sampler
Invert Float
Invert
Layered
Luminance
Maxon Noise
Mix
MultiSubTex
Noise Max
Normal Map
OCIO
Particle Sampler
Ramp
Remap
RGB to HSV
Sampler Info
Smoke
Softbox
Splat
Stucco
Tiles
TriPlanar
Context
UserColor
UVW to Color
Vector Product
Vertex Color
