Open Configuration – Opens a previously saved JSON configuration file that defines all the parameters necessary for the rendering and camera tracking. Clear Configuration – Clears the currently loaded configuration in the server. Apply Configuration – Applies any changes to the configuration that are made in the Server user interface. The camera tracking options are applied immediately after pressing Apply Configuration, most of the other options restart the rendering. Save Configuration – Saves all the parameters necessary for the rendering and camera tracking to a file in JSON format. Start/Stop – Starts/stops the Arena Server. Open Scene – Opens a .vrscene file. Append Scene – Import another .vrscene into the currently loaded scene. Stop Rendering – Stops the rendering process and closes the scene and the render instances. Another scene can be loaded after that using the Open Scene… button. Record Tracking – Records the camera tracking data to an Alembic file. |
