This guide provides steps for installing Chaos Bridge for SketchUp.
Note that the Chaos Bridge for SketchUp installation removes the V-Ray for SketchUp installation from your device.
Before running the installation, make sure your Windows account has administrative privileges.
Run the installer. Windows may ask you for permission to run the installer with administrator privileges. Please confirm.
Before running the installation, make sure your macOS account has administrative privileges.
Run the installer. macOS may ask you for permission to run the installer with administrator privileges. Please confirm.
Carefully read the End User License Agreement and the Global Consumer Privacy Policy. Click the I accept buttons if you agree to the terms.
Proceed to click the Continue button.
This screen allows you to select for which SketchUp version to install Chaos Bridge. You can also select more than one version at once.
Proceed to click the Install button.
Chaos Bridge installation is successful.
