This page provides information about Chaos Bridge for SketchUp.
Chaos Bridge is a compatibility plugin for SketchUp. Its main feature is its ability to export V-Ray scenes that can make their way into other Chaos products such as rendering integrations in other DCCs as well as standalone applications and services. The export of V-Ray scenes is available without a license.
Enscape and V-Ray data is exported following the V-Ray for SketchUp logic. To edit this data, install the corresponding Chaos plugin used for authoring it.
If you already use V-Ray for SketchUp and have it installed, you don't need to install Chaos Bridge. V-Ray for SketchUp is already fully capable of exporting vrscenes.
System Requirements
Check if your hardware matches the minimum requirements to run Chaos Bridge for SketchUp.
Installation
Find information about downloading and installing Chaos Bridge as an edu/commercial user.
Loading
Find information about running Chaos Bridge after its installation.
Menu
Find information about Chaos Bridge menu and its parameters.
Uninstall
Find information about how to uninstall Chaos Bridge.
