This node's properties can be found in the Node menu of the right-side panel of the V-Ray Node Editor or on the node itself.
Invert – Inverts the values of the Matrix. Rotation – Rotates the texture pattern in the X, Y, and Z axes. A value of 0 leaves the element unchanged on that axis. Scale – scales the texture pattern in the X, Y, and Z axes. A value of 0 leaves the element unchanged on that axis. |
