This page provides information about the Material ID Render Channel in V-Ray for Blender.
The Material ID Render Channel isolates objects with specific materials by Material ID for compositing purposes. This render channel provides a mask for individual objects and materials that is easy to select in compositing software.
This render channel either shows each material (by Material ID) as a solid unshaded color or stores the Material IDs as integer values within the EXR format or VRay Image Format file.
The Color (with Anti-Aliasing) method supports antialiasing at the edges of objects where they meet other objects or the background. The Integer (no Anti-Aliasing) method, which assigns a Material ID to each pixel in the render channel, does not support antialiasing as each pixel can have only a single Material ID assigned to it.
More than one Material ID render channel can be used if desired, for example, if you wish to have both solid-shaded color and integer-based render channels for maximum flexibility during compositing.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Matte > V-Ray Material ID
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping –
Filtering –  Applies an image filter to this channel.
