Channel Name – Customizable name for the render channel. Enable Deep Output – Specifies whether to include this render channel in deep images. Consider For Anti-Aliasing – When enabled, anti-aliasing is used where possible. Affect Matte Objects – Determines whether to include matte objects when generating the render channel. Filtering – Applies an image filter to this channel. Force 32 Bit Output – When enabled, stores the Extra Texture render channel as a 32-bit float even when writing a 16-bit raw image. This option applies only to multichannel .exr files. Force Lossless Compression – When enabled, lossy DWAA/DWAB compression is not applied to the Extra Tex data stored in a multichannel exr. This option applies only to multichannel .exr files. Denoise – Enables the render channel's denoising, provided the Denoiser is enabled. |
