Rendering Color Space – Color space to use for rendering,. Affects Sun/Sky, temperature color controls, and texture color conversion. For VFB to properly display ACEScg renders, use the respective OCIO config. The following options are available: sRGB – This will automatically reverse the gamma correction before the textures are used in the scene, using the reverse sRGB value of 0.454. If all your textures are JPG or PNG, this will result in true Linear Workflow. ACEScg
