November 18th, 2024 | Version: Chaos Corona 12 Update 1 | Plugin: Cinema 4D
Render engine
  • Biased and Unbiased solution
  • Path Tracing: unbiased solution
  • UHD and 4K (experimental) cache: two options for faster biased cached solution for interiors
  • Denoising
    • Reduces the number of passes needed to get a noise-free image, with render time reductions of 50 to 70%
    • Easy to use and fast to render
    • Corona High Quality denoiser, best quality, recommended for final renders
    • NVIDIA AI GPU-based denoising can be used for final renders at the user’s discretion (requires a compatible NVIDIA GPU)
    • Intel AI denoising can be used for final renders. CPU-only, and works with any CPU (not just Intel)
    • Interactive amount adjustment
    • Checkbox to enable/disable the result in the VFB
  • Fast Caustics Solver
    • Easy to use, and fast to render
    • Includes caustics from reflection, refraction, and dispersion (splitting light into separate colors)
    • Enable or disable caustics being visible through volumes
    • Adjust surface and volume caustic intensities independently
    • Enable or disable for specific light sources
    • Works with LightMix
    • Separate render element available for compositing caustics in post processing for even greater control
    • Works correctly with motion blur
    • Include/Exclude list for control over which objects receive caustics
  • Adaptive Image Sampling
    • Balances out the rendering calculations over the image to focus more processing power on tricky areas
  • High Quality Image filtering, gives a more natural and “less CGI” look to noise, making it less noticeable to the eye
  • AI Image Upscaling for faster test renders, particularly useful for draft animations; renders to one half of the image size and upscales (requires a compatible NVIDIA GPU)
  • Progressive rendering
  • Max Sample Intensity (MSI): automatically removes fireflies - accuracy/render speed tradeoff
  • Proudly CPU based
Interactive rendering
  • 100% the same render engine as for the final frame
  • All final frame rendering features supported, including Interactive LightMix, post-production effects such as bloom & glare, LUTs, etc.
  • NVIDIA AI GPU-based denoising, for denoising during Interactive Rendering (requires a compatible NVIDIA GPU)
  • AI Image Upscaling for faster redraw of Interactive Rendering; renders to one half of the image size and upscales (requires a compatible NVIDIA GPU)
  • Pick objects directly in the docked viewport, and use the standard Cinema 4D transform widgets on them
  • Image upscaling factor to allow rendering to a smaller resolution and upscaling (ideal for HighDPI displays)
  • While zooming-in in the IR, rendering is focused on visible area only
  • Subsampling lowers initial resolution at the beginning of rendering, for virtually real-time performance
  • Blue Noise Dithering to give visually pleasing results in the first few passes, for quick assessment of a scene when using Interactive Rendering
  • Results shown in Corona VFB or docked viewport
Chaos Vantage (sold separately)
  • Standalone application providing real time ray tracing on the GPU
  • Supports many Corona materials, lights, etc.
  • Live Link
    • Use as an alternative to Interactive Rendering in order to explore your scene from within Cinema 4D, find good camera angles, modify lighting, adjust materials, layout a scene, etc.
    • Use to quickly render the test animations created in Cinema 4D - supports all types of animation that can be created in Cinema 4D (if it is supported in Corona IR, it is supported in the Live Link)
    • One-click solution to open your scene in Vantage from 3ds Max
    • Changes in 3ds Max are automatically sent over to Vantage
  • Export your scene
    • Use for a full 3D walkthrough of the scene to explore it in detail
    • Build animations in Vantage itself for quick test renders
    • Send the scene to other Vantage users for them to view without them requiring Cinema 4D or Corona
Chaos Cosmos
  • Instant content for your scenes, including
    • Models
    • Materials
    • HDRI Skies
    • Scatter presets
    • Decal presets
    • Pattern presets
  • Accessible directly within 3ds Max or Cinema 4D
  • Content is categorized and easily searchable
  • Mark your favorites to find them quickly in other projects
  • Drag and drop anything you have downloaded into your 3D application
  • Content loads as Corona Proxies, with fully editable Corona Materials
  • On-demand downloads, only download what you need, when you need it
  • New content added between Corona releases
Chaos Scatter
  • Ideal for adding grass, trees, rocks, traffic or parked cars, crowds or pedestrians, etc. to your scenes
  • Can be used to scatter Decals
  • Can be used to scatter onto the results of other scatters
  • Control the distribution of hundreds, thousands, or millions of objects
  • Scatter on geometry, in a volume, or along splines
  • Distribute randomly, or in patterns
  • Limit distribution based on the steepness of a slope, e.g. prevent trees growing on cliffs etc.
  • Use spline include/excludes with controllable near and far parameters, e.g. to carve a path through trees, or limit flowers to a flowerbed
  • Edge Trimming to control and tidy the edging of scatters
  • Associated texture map that colors scattered objects based on the colors of the object they are scattered on – ideal for creating patterned rugs, variations in color on a lawn, etc.
  • Camera Clipping to limit scattering to within the camera field of view
  • Set scattered objects to look at a particular target
  • Extend view parameter allows expanding the camera view culling to allow correct shadows or reflections from instances outside of the field of view
  • Random translation/rotation/scaling of instances, with optional discrete stepped values
  • Optionally avoids objects intersections, with tweakable inter–object spacing
  • Supports aligning instances to local normal
  • Control density and scale by maps, including preset distribution maps
  • Different modes for using maps to control scatter scale, including RGB mode to define x, y, and z scaling independently in one map
  • Several display modes and limits, to keep viewports responsive
  • Position Distribution allows scattering the instances based on a pattern
Chaos Cloud for Collaboration
  • Chaos Cloud, for Collaboration
    • Share draft or final deliverables with your clients - removes the need to use dropbox, ftp, email communication with your clients for change requests, etc.
    • Send to Chaos Cloud directly from within the VFB
    • Call out particular information with Highlights non-destructively on an image
    • Receive comments from and have a conversation with your clients on change requests etc., with non-destructive markup on an image
    • Virtual Tours
      • Automatic recognition of when an image is a panorama (aspect ratio of 2:1)
      • Set up manual hotspots to move between panoramas, with a choice of hotspot icon, hotspot title (if any), and whether title is always shown or only on hover-over
      • Share the result with your client
      • Your client can then share with their target audience, e.g. via embedding on their website
    • Organize your work by project, and manage access and sharing for each separately
    • Deliverables can have versioning, to track the history of requests and changes
    • Optional manual upload of deliverables
    • Managed within a web browser environment
Materials
  • Corona Decal
    • Easily add surface details or imperfections, which can include displacement
    • Independently choose which channels (Diffuse, Displacement, Metalness, etc.) are affected by a Corona Decal
    • Control scaling, positioning, and rotation using a 3D object in the viewport – no need to fiddle with complex UV mapping and placement
    • Stack Decals on top of each other, intuitively controlled by positioning in the 3D space
    • Decals apply to all objects they overlap, with an include/exclude list for fine control
    • Can take a mask from the input material, or a dedicated Shader
    • Option to replace base displacement and base bump
    • Can be curved in width and height independently
    • “Fit to Bitmap” and “Fit to assigned mtl” to get correct aspect ratio for the Decal object
    • “Max angle limit” lets you avoid the decal being applied to backfaces, etc.
    • “Max angle blur” softens the transition from the “Max angle limit” control
    • Option to display the material as a preview in the 3D viewport
    • Easily bend labels around curved objects like bottles and spherical items without distortions.
  • Corona Slicer Material
    • Used to cut away sections of geometry at render time
    • Cut with any shape that has the Slicer material applied
    • Cuts through all objects overlapped by the slicer, customizable via exclude/include lists
    • Option to cap resulting exposed surfaces
    • Caps can have their own material, or take the material from the object being sliced
    • Can preserve interior lighting of a house with cutaway by combining with the RaySwitch Material
  • Corona Physical Material
    • Default material since Corona 7
    • Base Layer for diffuse, reflection, bump, and translucency controls
    • Base layer uses Oren-Nayar shading model
    • Clearcoat Layer for adding a layer of varnish, lacquer, etc., featuring separate bump from the Base Layer
    • Sheen for creating realistic fabrics
    • Choice of Roughness or Glossiness workflow, both per-material and as scene default
    • Choice of IOR or Disney Specular workflow, both per-material and as scene default
    • Metalness workflow, where Metalness can be mapped
    • Metals can be controlled by simple Edge Color, or by Complex IOR
    • UI interactively enables or disables parameters based on whether a material is Metal or Non-Metal
    • 35 presets built-in to the material, as starting points, or to ‘reverse engineer’ to learn in creating your own materials
    • Refraction, including dispersion, caustics, and thin absorption (for Thin Mode)
    • Anisotropy correctly affects both Refractions and Reflection (both correctly affect caustics)
    • Thin mode for glass correctly blurs reflections and refractions
    • Opacity
    • Adaptive displacement with low memory requirements
    • Vector displacement
    • SSS mode for wax, marble, and other materials that do not use Thin Mode or full Refraction
    • Volumetric scattering and absorption mode for fog, mist, and for colored glass, liquids and other materials that use Refraction without Thin Mode
    • Self-illumination
    • Adjustable PBR reflection tail
  • Corona Legacy Material
    • Uses Lambertian shading model
    • Legacy material, to preserve identical results from scenes created in earlier versions of Chaos Corona
  • Corona Select Material
    • Store multiple materials for one object, and select between them via radio buttons
    • Current Index parameter can be keyframed
  • Corona Skin Material
    • Dedicated material for skin
    • Three independent Subsurface Scattering layers
    • Two independent Reflection layers
  • Corona Hair Material
    • Dedicated material for hair and fur
    • Colored and Colorless reflection layers
    • Color controls via melanin amounts, or directly
    • Adjustable random Glints
    • Usable alone or in combination with Cinema 4D Hair Material for Cinema 4D's native control over the hair growth properties
  • Corona Layered Material
    • Alternative to Cinema 4D Texture Tags layering
    • Combines multiple materials
    • Individual layers can be toggled on/off
    • Displacement from the individual materials can be combined via blend or additive modes, or taken only from the base layer
  • Corona Light Material
    • Identical performance to Corona Light
    • Various non-physical settings
    • Textured emission (useful for backplates)
  • Corona Ray Switcher Material
    • Uses different material for different ray types: direct, GI, reflections, refractions
  • Corona Shadow Catcher Material
    • Use custom backplate texture or show the environment map behind
    • Supports glossy surfaces
    • Bump mapping
    • Lights work additively (illuminators) or subtractively
  • Corona Volume Material
    • Simplified material for volumetric scattering and absorption
    • “Inside Mode” allows for true 3D volumetric materials
  • Cinema 4D Materials
    • Cinema 4D PBR Material
Corona Node Material Editor
  • Global/World view of shaders and materials and how they are connected
  • Use views to organize materials and shaders by type, category, etc.
  • Handles all Corona and most Cinema 4D shaders and materials; also works with Substance shaders
  • Connect one shader to any number of channels, or materials
  • Works with native Cinema 4D Layer shader
  • Switch at any time between the Corona Node Material Editor, or the native Cinema 4D editor
  • Supports drag and drop from the Cinema 4D Asset Browser
  • Select by selection box
  • CTRL + Drag to copy selected nodes
  • Option to turn Corona Shared Shaders into regular shaders on saving the scene
  • Independent of Cinema 4D version – works in all versions of Cinema 4D supported by Chaos Corona (R14-R25)
Shaders
  • Corona Curvature
    • Add wear-and-tear or dirt to an object, based on the curves of the surface
    • Identify concave areas, convex areas, or both at once
    • Ray directionality to control how “focused” the effect is
    • Distance to control how far the effect extends
    • Color spread to control smoothness of blending between colors
  • Corona Distance
    • Gradient based on distance to other objects, including Cameras
    • Supports textures
    • List of objects to calculate distance from
    • Can be used with Cinema 4D Effectors to control placement of scattered objects
    • Wide range of other creative uses, e.g. ripples on water around objects, controlling light intensity and color, etc.
    • Supports splines
    • Works as an input to bump mapping, displacement, etc.
  • Corona Mixture
    • Advanced mix shader
    • Texture or color inputs, different blending modes
  • Corona Multi Shader
    • Randomly assigns colors/shaders to instances, mesh elements, Tiles (from the Corona Tile shader, see earlier), or decals
    • Frequency spinners
    • Hue and Gamma randomization
    • Features advanced blending modes
    • Global blur multiplier to affect all multi shader elements
    • Supports up to 100 inputs
    • Can be used with just one input, applying gamma and hue randomization
  • Corona Mapping Randomizer
    • Apply random offset / rotation / scale to shaders by instance, material id, mesh element, etc., which can be enabled separately or via checkboxes which allow multiple randomization modes at once
    • Options to allow randomization of seamless textures, e.g. to avoid visibly obvious tiling
    • Option to randomize by Tile from the Corona Tile shader (see “Corona Tile” earlier)
  • Corona Select Shader
    • Store multiple shaders, and select between them via radio buttons
  • CoronaSky
    • Duplicates the functionality of the Corona Sky object (see the Lights section), except for the Volume Effect.
  • Corona Tile
    • Create tiled walls, floors, and more
    • A variety of inbuilt tiling patterns
    • Overall scale
    • Tile color (which can be mapped)
    • Gap thickness, and color (which can be mapped)
    • Gap distortion for randomization
    • Gap blur to blend sharply or smoothly into the Tile color
    • Adjustable rounding of tile corners
    • Can be used as a map e.g. in a Layered Material
  • Corona AO
    • Ambient occlusion shader
    • Supports textures
    • Includes/Excludes
    • Additional controls: spread, directionality, inverted mode, etc.
  • Cinema 4D Normal Direction
    • This supported native Cinema 4D shader fully replaces the CoronaFrontBack texmap from the 3ds Max version
  • Corona Color Correct
    • Adjust brightness, saturation etc. of a texture map (and still have it affected by VFB post-processing)
    • Unique tone mapping capabilities (not present on other output nodes), including LUTs, gamma, green-magenta tint, etc.
    • Cinema 4D Filter Shader is supported and can be used as an equivalent for other tone mapping capabilities such as gamma, curves, etc.
  • Corona Tonemap Control
    • Specify whether a texture map should be affected by VFB Exposure, Tone Mapping, etc.
  • Corona Color Mix
    • Adds the Cinema 4D native color mixing settings to the shaders which normally don't have them
  • Corona Ray Switch
    • Same as RaySwitch material, but on shader instead of material level
  • Cinema 4D Color
    • This supported native Cinema 4D shader fully replaces the 3ds Max version's CoronaColor texmap
  • Corona Wire
    • Wire shader
    • Allows to set edge/vertex size in world or screen coordinates
    • Includes Falloff option
    • Can be used as an input to bump mapping
  • Corona Bitmap
    • UV Tiling, Crop / Placement, Channel outputs
    • Out-of-core Textures (enabled by default) saves memory by automatically adjusting textures based on their placement in the scene
    • Can load .tx files
  • Corona RoundEdges
    • Rounded corners shader
    • Works as an input to bump mapping and other material slots
  • Corona Edge Shader
    • Add weathering or staining to edges of objects
    • Creates a color gradient based on how far away a point is from a geometric edge
    • Primarily for objects with no thickness (paper, leaves, etc.)
  • Cinema 4D Variation
    • This supported native Cinema 4D shader fully replaces the CoronaMultiMap known from the 3ds Max version
  • Corona Triplanar
    • Apply textures without explicit UV mapping, with no stretching or seams thanks to the in-built blending
  • Corona Normal
    • Automatic detection of incorrect input gamma
Lights
  • Corona Sky Object
    • Procedural Clouds allow you to add, control, and animate clouds and airplane contrails
    • New PRG Sky model based on atmospheric data
    • “Aerial Perspective” via Volume Effect
    • Altitude sets the height of the observer
    • Turbidity controls whether sky is clear or overcast
    • Density controls the thickness / heaviness of the clouds
    • Clouds affected by the Sun’s Direct Color
    • Artistic control over Horizon Blur
    • Can be linked to a Corona Sun, allowing different times of day
    • Supports dawn/twilight with the Corona Sun as low as -12 degrees (approximately 24 sun diameters) below the horizon
    • Allows changing of the ground color
    • Also offers Hošek & Wilkie, Preetham et al., and Rawa-fake sky models
    • Alternatively can be set to use an HDRI, with Spherical and Dome mapping modes for use as an Environment
    • Multiple skies are supported, and each one can be paired with specific Corona Suns, for use in LightMix
    • In-built controls for Visible directly, in reflections, etc.
  • Corona Sun
    • Standalone object that can be combined with the Corona Sky Object for complete realistic outdoor lighting
    • Multiple Suns are supported, and each one can be paired with specific Corona Skies, for use in LightMix
    • Allows non-physical properties (changing size, color, disabling visibility in reflections, ...)
  • Corona Light
    • Shapes: sphere, rectangle, disk, cylinder
    • IES profiles
    • Directionality
    • Physical units
    • Color (RGB input, Kelvin temperature, texmap)
    • Non-physical settings: disabling shadows, includes/excludes, disabling visibility in reflections, preventing black appearance for lights with directionality
    • Turns any object into a light
    • No render time differences compared to using a CoronaLight
  • Cinema 4D native lights
  • Corona Sky Tag (for compatibility only)
    • Tag that can be applied onto Cinema 4D Sky Object for procedural sky light emission
    • For compatibility with old scenes only; the Corona Sky Object should be used in Chaos Corona 5 and newer
Interactive Lightmix
  • Adjust color and intensity of lights, during and after rendering
  • Single-click set up (by instances, groups, individual lights, or layers, with memory requirements reported)
  • Supports multiple suns and multiple environments for different times of day from one render (see Corona Sky and Corona Sun in the Lights section)
  • Manual set up if required
  • Controlled from the VFB
  • Results can be pushed to the scene
  • Can be used for anything from subtle adjustments, to turning day into night, without re-rendering
  • Create multiple Lightmix render elements to save your different set ups all in the same scene and/or CXR
  • Each light select pass can be denoised independently
  • Can select the light objects in a scene for a particular LightSelect layer, directly from the LightMix tab in the VFB
  • LightMix result can be saved to a CXR file and then adjusted in the Corona Image Editor, or saved for compositing in other post-processing software
Environment
  • Use a Corona Sky Object, or drag and drop a Corona Light Material with any shader or an environment map into the Scene environment slot in the Scene environment tab in Render Settings
  • Adaptive Environment Sampler ensures fast and accurate sampling of HDRI and Sky environments, without the need for portals
  • Importance sampling speeds up rendering
  • Direct/Reflect/Refract overrides in Render Settings
  • Global material for volumetric effects such as fog (also see Volume Effect under Corona Sky for an “aerial perspective” instead)
Corona Virtual Frame Buffer
  • An optional, feature-rich replacement for the Cinema 4D Picture Viewer
  • New VFB 2 for enhanced performance and controls (legacy VFB available as an option)
  • Integrated tone mapping controls
    • Fully customizable stack – add, delete, and move all the parameters to create precisely the effect you want
    • Presets to provide a starting point
    • Tone mapping stacks can be saved and loaded, independent of other VFB controls
    • Each Corona Camera can have its own unique tone mapping stack and settings, which are displayed and controlled in the VFB without having to edit the Camera settings
    • Included parameters:
      • Auto Adjustment - can be toggled on and off affecting the two settings below at once
        • Exposure - can be toggled on and off, baked to the scene, and allows additional manual Exposure adjustments
        • White Balance - can be toggled on and off, baked to the scene, and allows additional manual White Balance adjustments
      • Basic
        • Contrast
        • Green-Magenta Tint
        • Lift Gamma Gain
        • Photographic Exposure
        • Saturation
        • Simple Exposure
        • Tint
        • Vignette
        • White Balance
        • Legacy White Balance
      • Curve Control
        • Advanced Filmic Mapping
        • Curves
        • Filmic Mapping
        • Tone Curve
      • Highlight Control
        • Reinhard Highlight Compression
      • Final Look
        • ACES Output Transform
        • LUT
  • Integrated Interactive LightMix, allows changing color and intensity of lights without re-rendering, including multiple LightMix layers for storing different lighting settings within the image (day, night, etc.)
  • Integrated lens effects offering a high degree of realism and creativity for bloom & glare effects affected by lens scratches, dirt, etc. Includes option to defer the calculation until render end, rather than recalculate as rendering happens
  • Sharpening/blurring
  • Save and load post-processing and LightMix configurations, and exchange those to and from the Corona Image Editor
  • Pick objects directly in the VFB
  • Set DOF focus point directly in the VFB (for Corona Cameras)
  • VFB History and Comparison, with ability to toggle between using the current post-processing, or the post-processing at the time of saving the image to history
    • Load or drag-and-drop images into the VFB history
    • A/B Compare images of different resolutions or aspect ratios
  • Statistics: render time, remaining time, performance, polycount, tooltip explanations, etc.
  • Displaying/saving Multi-Pass layers
  • Pixel color probe on right mouse button
  • Controls: start render/stop render, resume last render, resume rendering from file, save/clone/copy image, etc.
  • Optional stamp with scene info at the bottom of rendered image
  • Customizable information in the title bar
  • Interactive and Multiple Render Regions
  • Fuzzy render regions
  • Zoom buttons for use when accessing a machine remotely
  • Can be set to use the same color space as the native Cinema 4D Picture Viewer
  • Automatic Exposure and White Balance (Auto Adjustments)
Corona Image Editor
  • Runs outside of any 3D software
  • All the familiar controls from the Corona VFB
  • Adjust lighting in the rendered image using the full range of LightMix controls (on Corona EXRs)
  • Apply Denoising (on Corona EXRs)
  • Apply all the Corona post-processing options (on any EXR)
  • Save and load LightMix and post-processing configurations, and exchange those to and from the Corona VFB
  • Bloom & Glare virtual element which can be viewed or saved separately
  • Save up to eleven formats (EXR, PNG, JPG, BMP ...)
Geometry
  • Corona Pattern
    • Tile geometry as easily as tiling a texture
    • Greater realism than maps of opacity, displacement etc. and needs less memory
    • Use scene geometry (cube) to define the crop box, taking advantage of e.g. snapping
  • Corona Proxy
    • Cross-platform proxy format: .cgeo
    • Faster save/load/display of large scenes
    • Compressed format to save disk space
    • Supports animated meshes
    • Duplicate to mesh functionality, which lets you create a separate, regular polygonal model that you can edit using the C4D modeling tools
    • Supports loading of vrmesh proxies (mesh data only)
  • Corona Volume Grid
    • Allows loading and rendering of OpenVDB files
    • Useful for importing simulations such as clouds, smoke, fire, liquids, etc.
Post-processing effects
  • Controlled from render settings, Corona Camera, or VFB
  • All settings are adjustable during/after rendering
  • Image updated in real time
  • Bloom & Glare
    • Both controlled independently
    • Threshold
    • Color intensity & shift to adjust colors
    • Glare ray count, blurriness and rotation
    • Lens Effects for scratches, dirt, etc.
Corona Camera
  • Corona Camera is a tag allowing to use all the standard Cinema 4D camera controls plus all Corona controls such as exposure, DOF, LUTs etc.
  • Shutter Curve for flexible control of Motion Blur
  • Focus distance can be set using the native Cinema 4D Focus Object functionality
  • Tone mapping parameters respond immediately in Interactive Rendering without restarts
  • Render to fisheye, orthographic, perspective, spherical, cylindrical, or cubemap projections
  • DOF supported for Fisheye renders
  • Per-camera object includes / excludes
  • Camera can move through volumes (e.g. be half submerged in water, showing above and below the water at the same time, or fly through clouds, etc.)
Camera effects
  • High quality (raytraced) depth of field and motion blur effects
  • Photographic controls (optional): shutter speed + ISO + f-stop
  • Fisheye lens effects
  • Bokeh shape
    • Circular
    • N-gonal (bladed aperture)
    • Custom image
    • Center Bias
    • Vignetting
    • Anisotropy
  • Multi-segment (curved) motion blur
  • Virtual Reality Camera
Exposure and color mapping
  • Controlled from render settings, Corona Camera Tag, VFB, or Picture Viewer
  • Two exposure control modes
    • Photographic exposure: shutter speed + ISO + f-stop
    • Simple exposure: single EV value
  • See the Corona Virtual Frame Buffer section for a full list of controls
Distributed rendering
  • Support for Cinema 4D Team Render of both animations and single frame
  • Pass, Time and Noise Level limits can be used
Corona Unified Lister
  • Provides access to and control over the major parameters of any Corona Lights, Light Materials, Suns, Proxies, Displacement Materials, Cameras, and Scatters in the scene
Multi-pass
  • Arbitrary number of passes
  • Optional anti-aliasing of passes
  • Optional Denoising of passes (where relevant)
  • Beauty pass, with independent Denoise amount
  • Alpha pass
  • Beauty composition passes
    • Direct, indirect, reflect, refract, translucency, emission, caustics, volumetrics
  • Geometry passes
    • Geometry normals, shading normals, primitive coordinates, UVW coordinates, world position, z-depth
  • Masking passes
    • Wire color
    • Primitive/Material/Object ID
    • Cryptomatte
    • Option to propagate masks through reflection, refraction, both, none, or never
    • Mask propagation can now be enabled or disabled for Mask, ID, ZDepth, WireColor and Texmap multi-passes
    • Custom mask
      • Object selection
      • Material ID
      • Object buffer ID
  • Shading passes
    • Albedo, individual direct/indirect BRDF components, raw components, source colors, shadows, bloom & glare
  • Informational passes
    • RenderStamp, SamplingFocus
  • Arbitrary texmap elements
    • Corona AO shader
    • Corona Wire shader
Supported Chaos tools
  • Chaos Cosmos and Chaos Scatter included
  • Chaos Scans compatibility (license also included with Corona Premium subscription)
  • Chaos Player license included with Corona Premium subscription
  • Chaos Phoenix license included with Corona Premium subscription (note: currently, there is no Phoenix for Cinema 4D)
Supported Cinema 4D features
  • Most native and 3rd party shaders
    • Evaluated directly from the Corona rendering pipeline
    • Including the Cinema 4D shaders Beat, Bitmap, Brick, Checkerboard, Cloud, Color, Color(MoGraph), Colorizer, Cyclone, Display Color, Distorter, Earth, Falloff, Filter, Fire, Flame, Formula, Fresnel, Fusion, Galaxy, Gradient, Layer, Lens Distortion, Marble, Metal, Multi, Noise, Normal Direction, Pavement, Pixel, Planet, Polygon Hair, Posterizer, Projector, Proximal, Ripple, Rust, Simple Noise, Simple Turbolence, Spline, Starfield, Stars, Substance Shader, Sunburst, Thin Film, Tiles, Variation, Venus, Vertex Map, Water, Weathering, Wood
  • Cinema 4D native material layering
    • Including turning off shadows or non-physical falloff properties
  • Cinema 4D render options
    • Render region, viewport render region, interactive render region, render view
  • Cinema 4D Background Object support
  • Native Team Render support
  • Render takes
  • XREF object in non-generator mode
  • Pyro support
VR
  • Corona Camera can render to spherical or cubemap format, supporting a wide range of VR apps
  • Easy setup, defaults handle 99% of cases
  • Conventional stereo rendering (non-360)
  • Bloom & Glare supported for spherical VR images
MISC
  • 2.5 D Displacement
    This method of calculating displacement saves significant memory and parsing times
  • Tooltips added for Corona Materials
  • Spline Rendering tag allows splines to render directly in Corona
  • Material and light conversion
    Cinema 4D lights and basic materials are rendered out-of-the-box using implicit conversion inside Corona without user interaction
    Basic implicit support for V-Ray Advanced, Standard, Displacement and 2-Sided materials
    Basic implicit support for V-Ray Physical Sun + Sky light and Area lights
    Other V-Ray lights which use Cinema 4D objects as their base are rendered using the Cinema 4D light's properties
    Explicit user-initiated conversion (via Corona menu, Convert Scene), which converts the supported Cinema 4D materials, Cinema 4D render settings, V-Ray lights, V-Ray materials, and V-Ray render settings to their Corona counterparts to allow further tweaking and changes in Corona
  • Advanced “Render Selected”
    Render mask by an include list, object ID, or viewport selection
  • Improved Color Picker
    Used for Corona-specific color editing, e.g. tone mapping parameters in the VFB
    Choice between sRGB modes for ease of use with Photoshop and similar, or Linear modes
    Perceptually uniform color gradients in both modes
    Color selection by RGB, HSV, CMYK, or Temperature
    Choice between 0-255, 0-1, or 0-100% for values
    Adjustable averaging of neighboring pixels
    Inverse color picker allows setting of white balance in combination with the Color Tint parameter in the VFB
  • Improved material editor scene
    More representative previews
  • Hair support
    Cinema 4D native Hair Object
    Cinema 4D native Hair Material in the Cinema 4D Hair Tag
    Corona Hair Material can be used in addition to Cinema 4D Hair Material for realistic hair appearance
  • Stacked materials work as expected with displacement
  • Override material option (with excludes/includes for objects and/or materials; options to preserve displacement, light materials, glass materials, slicer materials, bump mapping, opacity, portals, and unsupported materials; also works with complex generators, e.g. Extrude)
  • Save and resume
    Ability to save VFB and resume rendering later (even on a different computer)
  • Render only masks
    Computes render masks in seconds without doing shading
  • Autosave
    Optionally saving the VFB every few minutes and after rendering. Rendering can be resumed from these backups
  • Bundled LUTs
    Over 70 LUTs included with the install
  • Bundled IES profiles
    Sample IES files included
  • UI supports HiDPI monitors
  • Color Management options in Cinema 4D
