Chaos Envision lets you create and manage as many variations of your current project as you need. You can use these variations to explore design options or even animate between them. In the Environment tab, you can create variations of the environment lighting of the scene. Across these variations, you can modify all environment lighting parameters found in the Environment right-hand side tab, and achieve different lighting scenarios. Within the Envision timeline, the environment variations have their own track, allowing you to creatively combine and transition between them. Selecting a variation from the variations list updates the viewport immediately in real time. Alternatively, you can switch between environment variations from the current view quick settings. |
