Please make sure that your system fulfills these requirements before installing V-Ray. For additional information on hardware, see the Hardware Recommendations article.
Processor | Intel* 64, AMD64 or compatible processor with AVX2 support |
RAM | Minimum 8 GB RAM, recommended 16 GB RAM |
Hard Disk Space | minimum 2GB, recommended 12GB (includes additional downloadable content) |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported |
Operating System | Windows 10, Windows 11 |
SketchUp | SketchUp 2021, 2022, 2023, 2024 |
GPU Support | NVIDIA GPUs of Maxwell generation or later with the latest recommended video driver (for both CUDA and RTX - enabled cards) V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities |
Processor | Intel 64, AMD64, ARM64 or compatible processor with AVX2 support |
Operating System | Apple® macOS 10.15 Catalina or higher |
In V-Ray 7, macOS Metal support has been added on Sonoma, Sequoia and newer OS. |
Customer support is available only for V-Ray 6 and later. Earlier versions are no longer supported. |
Windows 11 is required for running Intel Alder Lake processors. |
