This page provides information about the recommended graphics drivers by Enscape.
Enscape should work if your GPU is capable of running the minimum recommended drivers listed below.
Although we always advise that you should be running the latest available drivers for your GPU, sometimes the latest available GPU drivers can cause unforeseen issues and in such a case we strongly advise that you roll back to the drivers listed here.
If you run into trouble, let us know by using Enscape’s Feedback function or contact us here. There are plenty of different system configurations and we are working every day to support more of them.
Since the GPU drivers are part of macOS, you do not need to worry about the GPU drivers as long as you are using Monterey 12.6 or a newer version.
