This page provides information about the .
The Chaos AI Enhancer allows you to elevate the quality of your visualizations, specifically Enscape people and vegetation assets. The AI Enhancer tool can be accessed from within the Enscape Viewport User Interface (UI) toolbar. To access the AI Enhancer, you must be logged in to your Chaos account with a non-trial license.
AI Enhancer button in Enscape
If the button is grayed out, you need to log into your account. A tooltip will remind you of this step. |
Using the AI Enhancer
To start using the AI Enhancer, simply go to a named view or navigate inside your Enscape viewport to set up a view you want to export. The AI Enhancer works similar to the Screenshot button. However, the screenshot is exported to your Chaos Cloud account for enhancement. Simply click on the AI Enhancer button and a status window will pop up confirming that your screenshot is being rendered. |
Rendering Image |
Once the image is rendered, the Chaos Cloud window will open up, asking you to define the name and location of the image in your Cloud account. You can either choose an existing project folder location, or create a new folder. |
Chaos Cloud Window |
When you click Upload and enhance, you will be able to view the status bar for your upload. When the image has been successfully uploaded, you will be notified in that window, and a button ‘View in Cloud‘ will show up. When you click this button, it will open the exported screenshot in your Chaos Cloud account.
Upload Status Bar |
View in Cloud Button |
By opening up the exported screenshot in your Cloud Account, you will be able to view the Enhancing… status at the bottom. |
Enhancing your image |
Once your image is enhanced, the enhanced version of the image will automatically open up, and a notification will pop up, confirming that your image was enhanced successfully. |
Image enhanced successfully |
You can use the compare versions feature in your Chaos Cloud account to compare the original and the enhanced version of your image as shown below. You can keep on uploading additional renders through the AI Enhancer button in Enscape. This will not stop you from using Enscape. The enhancement takes place directly in your Chaos Cloud account. To learn more about the AI Enhancer, check out the video tutorial. |
