Apart from the mentioned settings, there’s also a few settings affecting only the export quality of still image renderings, panoramas and video files, but not the real-time performance. To be precise, you could probably call the majority of available settings “quality” settings, depending on your personal taste, but these four will improve the output quality while either increasing render time, or output size. All of these options are located in Visual Settings window under the Output settings tab.
Resolution – Select the export resolution for both, your still image renderings as well as your video exports using this dropdown menu. You can either choose your window resolution, any of the given presets, or a custom resolution up to 8192 x 8192 pixels. Please be aware that exporting renderings in such high resolutions can overwhelm your graphics card, in extreme cases causing Enscape to shut down. Compr. Quality – The compression quality slider determines the output bitrate of your video files. This setting does not affect render time, only the resulting video file size. So feel free to dial this setting up to Maximum. For even higher quality, dial it all to the right to ‘Losless’ – this, however, will result in a series of PNG images – easily hundreds of them – that you can then combine to a video file using third party software. Keep in mind not to save this video on your Desktop, or you’ll have a lot of files to move around! FPS – The FPS (Frames Per Second) setting decides how many images are generated per second of your video. Twice the amount of frames per second, for example 30 -> 60, will result in twice the time it takes to render the video, but will also make for a smoother playback. Panorama Resolution – The Panorama Resolution allows you to choose the quality of the panoramas generated using Enscape. You can choose a resolution from “Low” (2048 x 1024 pixels), “Normal” (4096 x 2048 pixels) to “High” (8192 x 4096 pixels). |
