This place provides information about assets in Enscape for Archicad.
Asset Placement is achieved via the Enscape Asset Library, which can be accessed in one of two ways:
Either from within the CAD toolbar or from within the Enscape Viewport User Interface (UI) toolbar.
This feature is available for both Enscape assets and Custom assets, but the complete feature is only available when the Asset Library is opened via the Enscape Viewport UI. The Asset Library dialog that is opened via Archicad only allows for basic Single Asset Placement. Once an asset has been placed, it becomes available to be edited using the tools accessed via the Asset Library when opened from within the Enscape Viewport UI.
This article focuses on the initial placement of assets via both methods. It begins by explaining the tools available in the Enscape Viewport UI, followed by the placement methods available in Archicad.
NOTE: If the Asset Library window or the Enscape Viewport is blocked by a notification stating that no seats are available on the current License Key, or that the License has expired, then please refer to the Activate License Key page.
Asset Library button in Archicad |
Asset Library button in the Enscape Viewport UI |
Asset Library in Enscape
With the Enscape Viewport open and in focus, open the Asset Library panel either by clicking on the Asset Library button in the Enscape Viewport UI toolbar or via the L key on your keyboard. The Asset Library panel in the Enscape Viewport, once opened, has the following options available: - Search Assets function
- Category and Tag filters
- Asset Placement tools
- Enscape and Custom Assets tabs
- Offline Asset Library
When Asset Placement is in progress in the CAD Viewport UI, it also takes place simultaneously in the Enscape Viewport. However, a notification is shown, reminding you that there is an ongoing placement in progress. In case of conflicting changes, the CAD Viewport takes priority. |
Ongoing Asset Placement notification |
Placement in Enscape
The full feature set is only available when opening the Asset Library via the Enscape Viewport UI. When opening the Asset Library via Archicad only Single Asset Placement is available. Once assets have been placed in Archicad, they are then available for further editing from within the Enscape Viewport UI Asset Library.
The Asset Library interface allows you to narrow down your choice via the Search field. To refine your search further, you can also click on the Categories and Tags buttons.
Asset search tools
Once an asset has been selected, move the mouse in the Enscape Viewport over a surface in the project you would like to place the asset on. A low-poly approximation (proxy) of the asset helps you determine its position. Once you’ve decided where the asset is placed, click on its surface to fix the asset position, which continues to be shown as a proxy asset. Multiple instances of a single asset can be placed by continuing to click on surfaces within the Enscape Viewport. To confirm the asset positioning, click on the Apply Changes button after which the proxy will be swapped out with the complete asset geometry and its associated textures. To successfully place an asset in the Enscape Viewport, there needs to be a surface available in the project. |
Whilst an asset is selected, multiple instances can be placed by clicking multiple times on any available surface. |
Asset Positioning and Scaling
Once an asset has been placed, individual assets can then be selected, moved, rotated, scaled, and deleted from within the Enscape Viewport UI by using the transformation tools that are available in the Asset Library panel. The available tools in the Asset Library are, from top to bottom: |
Translate
The Translate tool allows you to reposition an asset that has already been placed. It can also be quickly accessed by pressing the T key on your keyboard as long as the Asset Library panel is open in Enscape, before or after selecting an asset. A set of control points appears around the selected asset in the Enscape Viewport. To move the asset, click on the arrows and drag and drop it on the desired surface. To rotate it, click and drag the green ring left or right. Additionally, you can move it freely by clicking on the orange control point located in the center of the asset. You can only drag and drop the asset to an area where a surface exists. You can also use X, Y, and Z coordinates for a more precise placement. You can find these input fields at the bottom left of the Enscape Viewport. To confirm the changes, click on the Apply Changes button. |
Scale
The Scale tool allows you to increase/decrease the size of an asset. Once an asset has been selected, three control handles appear around the selected asset. By clicking and dragging your mouse from left to right (up/down), the asset scales up/down on all axes symmetrically. Precision scaling the selected asset can be achieved via the input fields located at the bottom left of the screen. To implement changes, click the Apply Changes button. |
Delete
After assets have been placed and changes have been applied, the assets can be selected individually and then deleted from the project by clicking on the Trash Can icon. This can also be achieved by pressing the Del key on your keyboard or by right-clicking on the asset and selecting Delete Selection. To implement any changes, click the Apply Changes button. To recover the deleted asset, |
Multi Asset Placement
To speed up the asset placement on large surfaces, you can use the Multi Asset Placement tool. After clicking on the Multiple Asset Placement icon additional options become available below the Asset Library. The first step to placing multiple assets is to select all the needed assets. Single or multiple assets can be selected. Selected assets receive a check box and are also shown under the Selected Assets area at the bottom of the Enscape Viewport UI.
Selected Assets
Click on the checkbox in the asset thumbnail either in the Asset Library panel or under the Selected Assets area to remove those assets from the selection. To remove all assets at once, click the Clear All option in the Selected Assets area. If you click on Confirm Placement, the current placement can be undone by clicking Discard All. If assets are added or removed by unchecking them, all assets in the current selection are repositioned. |
Before or after selecting the assets, you need to select one of the selection tools to scatter the assets on a surface. There are three options available: - Rectangular Selection
- Circular Selection
- Bucket Selection
Area selection tools
During the asset placement process, the selection tool cannot be changed until the Confirm Placement button has been clicked. Alternatively, you can click the Clear All option or uncheck all selected assets in the Selected Assets area first. |
Click on the image to view it in full size |
Selecting the Rectangular Selection option provides a way to stipulate a limited area to place the assets. Once selected, moving the mouse over a surface in the Enscape Viewport reveals a circle with a control point in the middle to assist in choosing the origin of the rectangular area. Once you click on the surface to specify the origin point, two orange control points appear. One control point anchors itself to the surface to act as a pivot point and the other follows the mouse movement to specify the length of the rectangle. When you click to specify the length of the rectangular area, some proxy assets appear within that specified area. You can increase the width of the rectangle at any point during this process by adjusting the Width slider located below the three selection tools.
You can continue to adjust the size and orientation of the rectangle by clicking on either one of the control points. The assets are recalculated and regenerated to accommodate changes made to the selection area. You can make adjustments уп until you click on the Confirm Placement button. After that, you can continue to specify other selection areas. After you click on the Apply Changes button, the full asset geometry and the associated asset textures are placed in the project. At that point, the individual assets are available for individual editing or deletion. If you want to start placement again, click on the Discard All button. |
Circular Selection
The Circular Selection tool allows you to specify a circular area to place assets. - The first click specifies the center point of the circular selection, and two control points appear. The center control point specifies the pivot point, and the second control point specifies the initial diameter of the circular area.
- Once specified, asset proxy models appear within the defined area. You can continue adjusting the size and position of the area with the orange control points.
Click on Confirm Placement to continue creating other areas. Click Apply Changes when you are done placing assets to load the full geometry and textures and allow for individual asset editing. If you want to start placement again, click on the Discard All button. |
Bucket Selection
The Bucket Selection tool places assets on an available surface. Hovering the mouse around in the Enscape Viewport when the Bucket Selection tool is selected shows a bucket symbol instead of the mouse pointer, and any surfaces that are available for asset placement are highlighted as you hover over them. Once a surface for asset placement has been identified, click on that highlighted surface, and proxy models of the selected assets are placed on that surface as a preview. That means the assets are not fixed in place until you click on the Confirm Placement button. If you click on another surface before clicking the Confirm Placement button, the proxy assets are removed from the previous surface and applied to the newly selected surface. When you are happy with the asset placement, click on Confirm Placement and then Apply Changes to finalize the placement. If you want to start placement again, click the Discard All button. |
Density
The Density tool determines how many assets are placed in total.
For example, you may have only chosen a total of three assets from the Asset Library. Adjusting the Density slider increases or decreases the number of assets to be placed in the selected area or on the selected surface. This is particularly useful for placing vegetation.
Using the highest density could potentially lead to performance issues on large surfaces. |
Distribution
The Distribution dropdown menu determines the way in which the assets are placed.
The options available include:
- Random - No placement pattern is followed, and assets are placed randomly. This option is better suited for large surfaces.
- Jitter - Assets are placed on a grid-based layout but with a random offset. In large areas, the pattern may be more easily noticeable.
- Uniform - Assets are placed on a grid layout.
Random Rotation
When the Random Rotation checkbox is enabled, it randomizes the selected assets on the XY plane. This option is enabled by default. If disabled, all placed assets in the current selection, face the same direction. This can be useful when placing a group of spectators, for example. |
Preview Selected Area
If Preview Selected Area is enabled, the complete asset geometry and textures are loaded and shown in the Enscape Viewport.
Regenerate
If the Regenerate button is clicked, the selected assets appear in another position, specified by the currently active placement settings (Density, Distribution, and Random Rotation).
After the Regenerate button is clicked, the Preview Selected Area option is disabled.
Confirm Placement
Clicking on the Confirm Placement button fixes the assets' position, although the assets continue to be shown as the low poly proxy version by default.
Once Confirm Placement has been clicked, assets can not be edited or deleted as a group and must be dealt with individually. Additionally, the area selection guides disappear.
Alternatively, you can simply click Undo in the Archicad UI.
Apply Changes
Click the Apply Changes button to load the full asset geometry and its associated textures (if Preview Selected Area is disabled). Apply Changes only becomes available after Confirm Placement has been clicked. This is also valid for Single Asset Placement.
Discard All
The Discard All button is only available once Confirm Placement has been clicked, and it removes any changes that have not been applied.
Performance Considerations When using the asset placement tool, multiple assets are placed simultaneously, and depending on the area and density of assets placed, memory use could increase considerably. |
Multi-Asset Editing
With the Multi-Asset Editing feature, you can select a group of assets from your project model, instead of selecting them one by one. You can select assets visible in your Enscape Viewport by pressing the Shift key on your keyboard and dragging a selection area with your mouse pointer simultaneously over the screen. All selected assets are displayed as groups on the left sidebar. You can easily select and modify assets from that list. |
You can select all instances of an asset by right-clicking on the asset while the Asset Library is open in Enscape and clicking Select All [asset_name] assets. |
You can delete all selected assets at once by right-clicking on any of them and clicking Delete Selection. |
Asset Library in Archicad
When the Asset Library is opened via Archicad, initial placement of assets must be performed in the Archicad UI and it is only possible to place single assets this way. The tools provided within the Enscape Viewport UI to scale and move an asset and the Multi Asset Placement feature are only available when opening the Asset Library from within the Enscape Viewport UI. The Placement in Archicad section explains how to place assets in Archicad. This is only possible when the Asset Library is opened through the button in the Archicad toolbar. The Asset Library, when opened via Archicad, does not require the Enscape Viewport to be open. |
Archicad Asset Library dialog |
To place an asset in Archicad, open the Asset Library and choose your asset. Hover the mouse in the active Archicad 3D viewport, and you can see that a shaded area, representing the footprint of the asset, is displayed. Once you have chosen the location to place your asset, left-click, and the asset appears in the Archicad viewport, while it's still fully rendered in the Enscape window. You may need to rotate and align it to the surface using the appropriate Archicad tools. To place a different or an instance of the same asset, return to the Asset Library and make a new selection. |
