Potentially, a mixture of linked and non-linked Views can be batch rendered, with non-linked Views using the current Visual Settings and the linked Named Views using the linked Setting Preset. The Default Folder option is also available for Batch Rendering, and this means that when linking a View to a Setting Preset that has a different Default Folder specified, the associated location will be respected when Batch Rendering takes place, so your renders can be targeted to specific folders if desired. Automatic Naming has no effect when Batch Rendering, and the files are always named with the timestamp of when the image was rendered whilst also being appended with the name of that View. The Show Safe Frame option is always disabled when rendering via the Batch Rendering feature. |
