Spot lights work like a combination of Directional and Point lights. The light is projected in a specific direction, but is aimed at a specific object, like a flashlight. Click to place the spot light, drag to specify the light direction/target, and then click again to set the spot light. Use the Look To Height parameter in the Object Info palette to set an exact height. Once in place, you can only see the target handle and projection line when the spot light is selected. To move the light after it has been placed, or to adjust the target handle, use the Selection tool. Select the “Spot Light Specs” to specify the angle of the beam/spread, and the Distance Falloff.
Unlike Vectorworks, in Enscape there is a “cut off” of how far light from spotlights will travel, which was originally calibrated based on inside lights. So if you are using outside spotlights, you may need to increase the brightness in Vectorworks in order for them to show up as you want in Enscape. |
