The sun can have a dramatic effect on your project’s look and feel. Additionally to being able to quickly adjust the sun directly in the Enscape window, Enscape can also interpret the Geolocation and Time of Year settings from Vectorworks for the sun to be positioned correctly. You can quickly adjust the sun settings in Enscape by using various key combinations listed below.
Controls | Action | |
Time of day
| Press U or I to adjust the time of day. |
| You can also use Shift + Right Mouse Button while dragging the mouse right or left. | |
Solar angle |
| Press Shift + U or I to adjust the Solar angle. |
Solar rotation |
| Press Ctrl + U or I to adjust the Solar rotation. |
Reset Sun Position | Press the Home key to reset modifications made to the sun position. |
Generally speaking the Sun Settings and Geolocation are adjusted in Vectorworks, and the Geolocation will affect the position of the Sun when adjusting the time of year. You can also adjust the time of day in the Enscape window and save those settings for each view.
