Once you have finished setting up your camera and keyframes and the various options available to you, it can be exported as either MP4 or a series of PNG still image files, depending on the Compression Quality set in Enscape’s Visual Settings Output tab, or in the dialog that opens when you click the Export button at the bottom right of the Video Editor UI. It is not possible to pause the export process once it has begun, but you can press [ESC] to stop the export. The Export dialog allows you to override the settings that are made in the Enscape Visual Settings – Output tab. The dialog will allow to override the Resolution, including the Aspect Ratio if Resolution is set to Custom. Compression Quality settings Email, Web, Bluray, Maximum, will export MP4 (MPEG-4 (mp4v)) endcoded files. Lossless will export a series of uncompressed .png files, and this can end up taking a lot of space, so wherever you choose to store such an export, check you have enough space before hand. Frames per Second is also defined in both the Visual Settings Output tab as well as the Export dialog, under the FPS drop-down menu, where you can choose from 25fps, 30fps, 60fps and 120fps. |
