By having the Sun Options ‘Manual control’ unchecked, Rhino will display extended options to allow you to control precisely where you would like the location to be. You can adjust the time of year and time of day under the Date and Time area with the red sliders, or you can hit the Now button to use the current date and time. Location can be set by either clicking on the map, the location is indicated by a small red box on the map. You can click on the Here button, which will use your current location if available, or you can manually search by city, or set the Longitude and Latitude coordinates for better precision. |
