The time bar is found at the bottom of the interface. It has all the controls you need to play and simulate your animation, set the time span of the simulation, the framerate, and the playback speed. This interface can also be used to generate preview videos. Play – Click on the play button to preview the animation. Playback Range Start - Click and drag this marker to set the starting point of the playback range. When previewing the animations will loop within the range set using these markers. Current Frame Marker – Shows the current frame number and position. Click and drag this marker to scrub playback. Playback Range End – Click and drag this marker to set the starting point of the playback range. Time Setup options – Click this button to open the Time Setup options. Use these to set framerate, duration, playback speed, and preview render size. |
