Enabled – Turns on and off the sun light. Color – Changes the color of the sun and depends on the Color mode parameter. See the Sun Color examples below. Intensity – Specifies the intensity of the sun and can be used to reduce the default brightness. See the Sun Intensity examples below. Sun size mult. – Controls the visible size of the sun disc. This value can be used to control shadow softness cast from objects. Lower values produce sharp shadows, while large values produce softer shadows. See the Sun Size Multiplier examples below. Color mode – Affects the way the color in the Color parameter affects the color of the sun. See the Sun Color Mode examples below. Filter – Shifts the hue of the sun towards the color specified in the Color parameter. Direct – Sets the color of the sun to match the color in the Color parameter. In this case, the intensity of the light does not depend on the V-Ray Suns position in the sky and is controlled through the Intensity parameter. Override – Sets the color of the sun to match the color in the Color parameter but the intensity of the light still depends on the sun's position in the sky. Sun position mode – Specifies the control mode for the sun's position in the sky. Manual – Specifies a manual control of the sun position using the Rotate ( ) transform tool. Altitude/Azimuth – Specifies the use of Altitude and Azimuth values to control the sun's position. Geolocation – Specifies the use of location coordinates, date and time of day to control the sun position. Animated Geolocation – Specifies the use of location coordinates, date and time of day to control the sun position that can be animated in the Sun track in the animation editor. Invisible – When enabled, makes the sun invisible, both to the camera and to reflections. This is useful to prevent bright speckles on glossy surfaces where a ray with low probability hits the extremely bright sun disk. See the Sun Invisible example below. |
