The following parameters are available for Image mode: Color – Specifies a color as a background when Background Image is empty. When a background image is loaded through the Load background option, the color has no effect. Load background – Specifies an image to use as a background. RGB color space – Specifies the RGB color space of the background image. Auto – The color space is deduced by the file's name. Raw – No transformation is applied to R|G|B colors. sRGB – The loaded image is considered in sRGB color space. ACEScg – The loaded image is considered in ACEScg color space. Mapping – Specifies the mapping method for the image - spherical or screen. See the Mapping example below. Rotation – Specifies a rotation angle in degrees for the background image. Available when Spherical is set for Mapping. Flip horizontally – Reverses the image along the vertical axis, swapping the left and right sides. The vertical position remains unchanged. In short, the image is flipped horizontally. Fit – Controls how the environment texture is mapped to the camera view. It offers three modes:
Inside – Maps the environment texture to fit the camera view height while keeping the texture proportions. Outside – Maps the environment texture to fit the camera view width while keeping the texture proportions. Stretch – Stretches the environment texture to fit the camera view without keeping the texture proportions. Intensity – Specifies the intensity for the background image/color. Use for refraction/mirror reflection – When enabled, the background override is used for both refraction and perfect (glossiness=1) reflection rays. See the Use for Refraction/Mirror Reflection example below. |
