This page provides a guide to the V-Ray user attributes.
MoGraph Attributes in this list are applicable only to the MoGraph Cloner object when V-Ray User Color is applied to it. These attributes list the source, from which they gather data to feed into the User Color texture or node.
MoGraph Attributes | Cinema 4D Attributes | |
Color – The color value of the Cloner object. | Object Color – The default color of the object. This color can be changed from the project settings. | |
Color sRGB – the color of the Cloner object in sRGB color values. | Display Color – | |
ID Ratio (Color) – The index ratio of the Cloner as a grayscale color value. | Layer Color – The color of the layer that the object is placed in. | |
ID Ratio – The index ratio of the Cloner as a zero to one float value. | ||
Index (Normalized) – The index ratio of the clone as a zero to one float value. | ||
Weight – The MoGraph Weight attribute as a zero to one float value. | ||
Clone Offset – The MoGraph Clone Offset attribute as a zero to one float value. | ||
Time Offset – The MoGraph Time Offset attribute as a zero to one float value. | ||
Falloff Weight – The MoGraph Falloff Weight attribute as a zero to one float value | ||
Size – The Cloner's size attribute as a vector value. | ||
UVW – The Cloner's UVW attribute as a vector value. |
The MoGraph Attributes in this list apply only to the MoGraph Cloner object when V-Ray User Color is applied to it. Each attribute explains what kind of data it sources and where it sources it from.
