This pages provides information about the User Color Node in V-Ray for Cinema 4D.
The V-Ray User Color node texture can be used to read user-defined object properties from the current material and convert them to a color value. This allows you to use the same shading network on several different objects in the scene, but to control various aspects of the material through user-defined properties. For more information about user-defined properties (i.e., User Attributes), see the User Attributes Workflow page
This texture also has the ability to read mesh color sets, UV sets, and extra channel information from VRayProxy objects.
Properties
User Attribute – Specifies the name of the user attribute that is looked up and returned from this shading node.
Default Color – Specifies the color to return, if the user attribute is not found on the shaded object.
