Release Notes 30.04.2025
New
* With Revit 2026 now supported, Enscape continues to follow its policy of supporting the latest 4 Revit versions (2023–2026). As a result, Revit 2022 will be removed from the installer and no longer supported 3 months from the official release. We recommend updating to a supported version to ensure compatibility.
Improved Support for Revit Filters and Graphic Overrides: Enscape now supports Revit Filters and Graphics Overrides for linked models, enhancing visual consistency between Revit and Enscape renderings. The update also includes support for background patterns.
 Note: The “Custom” Display Settings option and accurate override display for nested links are not yet supported; these features will be added in a future release.
Removed Delay on Asset Placement: Eliminated the 0.25-second delay that previously occurred when placing an asset, resulting in a faster and more responsive asset placement experience. Improved Stability Through Better Error Handling: We’ve improved how Enscape handles internal settings issues to prevent crashes during startup.
Fixed Bugs
Unable to place an asset right after rotating around a model/surface (even if the camera has stopped)
Enscape 4.5.0 Is Not Detected By New Version Check: New versions are now correctly detected.
[SketchUp] Time of Day Resets When Creating a New View: The time of day remains the same after creating a new view.
[SketchUp][Enscape Impact] Performance map visualization does not respect sections: Performance map is now aligned with section planes.
[ArchiCAD] Parallel Light Export Error in Enscape 4.5: The light works as it did before
Known Issues
Color disappears when Intensity value changes. The emissive material resets its color to white as soon as you close the material editor.
