Tags allow you to tag this node with a descriptor that defines something about the machine, which we can later use to selectively control from inside SketchUp. For example, tags can denote whether this machine is one of a few with a powerful GPU or if it is not a workstation or a node on a render farm. For information on how to use Tags, see the Swarm Configuration page.
Once the render process is initiated, machines marked with the selected tags load the scene and assist with the rendering. |
