anima 6.1.0
Release Date: May 15, 2025
New features and Improvements
- Added support for named user accounts in the licensing system.
- Introduced a Depth of Field effect in the viewport for active cameras to enhance depth perception.
- Optimized memory usage and overall performance through various improvements.
- Added compatibility with older versions of 3ds Max.
- Added integration support for Pixotope.
- Enabled custom scaling for imported models.
- Enhanced decal rendering on paths and roads for improved visual fidelity.
- Improved shader rendering for escalators.
- Applied various visual enhancements to the user interface.
Bugfixing
- The installer now correctly detects install paths for C4D 2023 and 2024.
- Fixed synchronization issues with the render camera.
- Fixed issue where camera view was lost when switching scene tabs.
- Corrected trial days remaining displayed in the title bar.
- Uninstaller now removes all registry entries created by Anima.
- Fixed color variation IDs during crowd generation.
- Fixed collision issues with background geometry on path points and other tools.
- Fixed incorrect vertical orientation of people with some backgrounds.
- Resolved thumbnail generation errors for rigged characters in Edit Mode.
- In C4D, the app now closes properly after rendering via Commandline.exe.
- Fixed multiple log errors when rendering Anima scenes via Commandline.exe in C4D.
- Escalators now appear correctly in 3ds Max after scene reset and reload.
