This page provides information about the command-line or silent installation of Anima.
A silent installation allows a complete Anima installation to be performed without any user input during the process, using either the default options or, if desired, a predefined set of options. To set up a silent installation, follow the instructions below.
The simplest way to setup a silent installation is to run the installer file from the command prompt with the -gui=0 argument. This option forces the installer to run without a user interface, so no visual dialog shows and all the interactions happen through the console.
After that, answer the questions on the console when they come up. Then, the installation continues applying the default options, and a config.xml file is created. Inspect the XML file with a text editor and modify the options listed there to adapt them to your needs.
For example, using the command below, the only questions asked is to accept the EULA and GCPP:
anima_installer_6_1_0_baa9803d70.exe -gui=0 |
A config.xml file is created in the same folder where the installer is placed. Open that config.xml file with your preferred text editor, and modify any of the values listed there (refer to the details below to learn more about all the values).
Once the config.xml file is customized, use the -configFile option to force the installer to use the values specified:
anima_installer_6_1_0_baa9803d70.exe -configFile="config.xml" |
The following table contains a list of arguments and a description of the different values. When an argument has a possible value of 0 or 1, the values should be considered as 1 = true and 0 = false.
-debug | Specifies the level of debug logging by the installer [0-3]. Defaults to 0 and assumes a value of 1, if argument is provided with no value. Then, it creates a log file of the installation in the Temp folder of the current user. Sample path: C:\Users\<your_user_here>\AppData\Local\Temp\installer_debug_AAAA_MM_DD_hh_mm_ss.log |
-gui | Specifies if a Graphic User Interface or a command line one is used during installation. Defaults to 1. 0 – No Graphic User Interface is visible, so all the interactions happen through the command line. 1 – A Graphic User Interface is provided and the user can easily select the installation options. |
-quiet | Specifies whether the output of all the actions performed by the installer should be shown or not. Defaults to 1, which means that the "quiet" option is enabled, so the output info is minimal. 0 – Disabled, all the actions are shown in the console. 1 – Enabled, most actions are hidden from the console. |
-configFile | Specifies a path to an installation configuration file (i.e. "config.xml"). When used a -gui=0 argument is applied automatically, so no UI is shown. |
-backup | Specifies whether the installer performs backup on previous installation. 0 – Previous installation is not backed up. 1 – Previous installation is backed up. |
-auto | Automatically selects the default answers and values to all the questions asked. Notice this option will NOT accept automatically the EULA and GCPP. That can only be done by providing a config.xml file. |
If errors are encountered with quiet installation, -ignoreErrors specifies what further actions are taken. |
The config file can be used for easier console or script installations. The configuration file specifies the values of the variables used by the installer directly. The config file has a strict XML format, and will be rejected by the installer if it could not be parsed as such. All the variables specified by the configuration file will OVERWRITE default and registry loaded values of variables the installer has initialized previously. Generally the configuration file has to contain the following tags and attributes (here the VARIABLE_NAME and VARIABLE_VALUE refer to the variable name and value we wish to control in the installation).
<DefValues> <Value Name="VARIABLE_NAME" DataType="value">VARIABLE_VALUE</Value> </DefValues> |
A configuration file is automatically created by the installer whenever it runs with gui=0 (console mode). The file is created in the directory of the installer.
The following is the list of variables that can be used in the configuration file:
Variable Name | Description | Default Value |
STDROOT | Specifies the standard root directory for Anima installation. [path] | C:\Program Files\Chaos\Anima |
EULA_AGREED | Indicates if the End User License Agreement has been agreed to. [0/1] | 0 (not accepted) |
GCPP_AGREED | Indicates if the Global Consumer Privacy Policy has been agreed to. [0/1] | 0 (not accepted) |
INSTALL_TYPE | Defines the type of installation. [0/1] - 0: Workstation - 1: Render node | 0 (Workstation) |
INSTALL_MS_CPP | Indicates if the Microsoft C++ Redistributable should be installed. [0/1] **NOTE:** Only recommended for use if automatic detection fails. | autodetect |
INSTALL_MS_NET | Indicates if .NET features should be installed. [0/1] **NOTE:** Only recommended for use if automatic detection fails. | autodetect |
CREATE_DESKTOP_SHORTCUT | Controls if a desktop shortcut for Anima 6 should be created. [0/1] | 1 (create) |
LAUNCH_ANIMA | Controls if Anima 6 should be launched after installation. [0/1] | 1 (launch) |
PLUGIN_PPP_VVVV_INSTALL | Controls the installation of the plugin. [0/1] - PPP: target plugin (CIM, 3DS, UNR, PIX) - VVVV: version (2020, 2021, 2022, 2023, etc.) | autodetect |
PLUGIN_PPP_VVVV_PATH | Path of the target program of the plugin. [path] - PPP: target plugin (CIM, 3DS, UNR, PIX) - VVVV: version (2020, 2021, 2022, 2023, etc.) | autodetect |
The following is a list of all possible variable names for plugins in the current version of Anima (the "X" at the end should be changed to "INSTALL" or "PATH"):
Autodesk 3ds Max:
Cinema 4D:
Unreal Engine:
Pixotope:
anima_installer_6_1_0_baa9803d70.exe -configFile="config.xml" -debug=3 |
<?xml version="1.0" encoding="UTF-8"?> <DefValues> <Value Name="EULA_AGREED" DataType="value">1</Value> <Value Name="GCPP_AGREED" DataType="value">1</Value> <Value Name="STDROOT" DataType="value">C:\xxx\...\xxx</Value> <Value Name="INSTALL_TYPE" DataType="value">0</Value> <Value Name="INSTALL_MS_CPP" DataType="value">0</Value> <Value Name="INSTALL_MS_NET" DataType="value">0</Value> <Value Name="CREATE_DESKTOP_SHORTCUT" DataType="value">0</Value> <Value Name="LAUNCH_ANIMA" DataType="value">0</Value> </DefValues> |
<?xml version="1.0" encoding="UTF-8"?> <DefValues> <Value Name="EULA_AGREED" DataType="value">1</Value> <Value Name="GCPP_AGREED" DataType="value">1</Value> <Value Name="STDROOT" DataType="value">C:\xxx\...\xxx</Value> <Value Name="INSTALL_TYPE" DataType="value">1</Value> <Value Name="INSTALL_MS_CPP" DataType="value">0</Value> <Value Name="INSTALL_MS_NET" DataType="value">0</Value> <Value Name="CREATE_DESKTOP_SHORTCUT" DataType="value">0</Value> <Value Name="LAUNCH_ANIMA" DataType="value">0</Value> <Value Name="PLUGIN_3DS_2023_INSTALL" DataType="value">1</Value> <Value Name="PLUGIN_3DS_2023_PATH" DataType="value">C:\xxx\...\3ds Max 2023</Value> <Value Name="PLUGIN_3DS_2024_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_3DS_2025_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_3DS_2026_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_CIN_R26_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_CIN_2023_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_CIN_2024_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_CIN_2025_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_UNR_4.27_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_UNR_5.3_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_UNR_5.4_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_UNR_5.5_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_PIX_P23.1_INSTALL" DataType="value">0</Value> <Value Name="PLUGIN_PIX_P23.4_INSTALL" DataType="value">0</Value> </DefValues> |
