Panorama mode – When enabled, panorama images are displayed in panorama view. When switched off, the panorama image appears flat. Equirectangular/spherical panoramas, cube and stereo panoramas (left-right & top-down types) are supported in this mode.  Automatic – Calculates the orientation automatically to simulate movement in the correct direction based on the existing hotspots. (default) Original – Preserves the original default orientation as the image is rendered. Custom – Allows setting a custom starting orientation for panoramas. |
