The link icon provides access to the sharing options in Chaos Cloud Collaboration. Click the to open the Share popup window for folders, virtual tours, images, and projects. Email address – Adds an email address for the collaborator invitation. Select the user permission rights as Viewer or Editor. Members with access – Displays a list of the members that the content has been shared with and what type of access they have. Comments – Locks or unlocks comments for this item. If you lock comments, no new comments can be added, but people can still see the comment section. Set the comments option to Same as parent, to match the settings of the parent folder or project. Access – Sets the access type for this item. Same as parent – The item inherits the same setting as the folder or project has. Invited only – Only invited people are able to access the item. Anyone can view – Anyone who has the link can view the item. Anyone can comment – Anyone who has the link can view and comment on the item. Project access is fixed to invited only. Folder, virtual tour, and image access can be modified. |
Link - Provides link sharing options. Copy – Copies the link to the shared item.
– Opens the Scan QR code popup window. Download and send the code to provide a direct link to your Collaboration content. Sharing a file with multiple versions allows all versions to be seen by the members it is shared with. |
User PermissionsFor a full list of permissions by role, see the expandable below. User Type | Owner | Editor | Viewer |
Permissions | Owner | Can Edit | Can View |
Project level |
Open Project / View Project Info |  |  |  | Edit Project (Rename) |  |  |  | Delete Project |  |  |  | Delete Project Permanently |  |  |  | Restore Project |  |  |  | Share/Edit Project Permissions |  |  |  | Change Project Ownership |  |  |  | Create Folder in Project |  |  |  | Folder Level/Virtual Tours |
| Open Folder / Virtual Tour / View Folder Info |
|  |  | Edit Folder / Virtual Tour (Rename) |
|  |  | Move Folder / Virtual Tour |
|  |  | Delete Folder / Virtual Tour |
|  |  | Delete Folder / Virtual Tour Permanently |
|  |  | Restore Folder / Virtual Tour |
|  |  | Share Folder / Virtual Tour |
|  |  | Edit Folder / Virtual Tour Permissions |
|  |  | Add Comment to Folder / Virtual Tour |
|  |  | Reply to Comment in Folder / Virtual Tour |
|  |  | Resolve/Unresolve Comment in Folder / Virtual Tour |
|  |  | Remove Own Comment in Folder / Virtual Tour |
|  |  | Create File in Folder / Virtual Tour |
|  |  | File Level |
| Open File / View File Info |
|  |  | Edit File (Rename) |
|  |  | Move File |
|  |  | Delete File |
|  |  | Delete File Permanently |
|  |  | Restore File |
|  |  | Share File |
|  |  | Edit File Permissions |
|  |  | Add Comment to File |
|  |  | Reply to Comment in File |
|  |  | Resolve/Unresolve Comment in File |
|  |  | Remove Own Comment in File |
|  |  | See/Compare File Versions |
|  |  | Upload New File Version |
|  |  | Remove File Version |
|  |  | Add/Edit Hotspot |
|  |  | Add/Edit Highlight |
|  |  | View Hotspot |
|  |  | View Highlight |
