This page provides information about the Virtual tour floor plan.
Any flat image can be utilized as the floor plan for the space. This interactive feature significantly enhances navigation by allowing you to easily move between different spaces. Once the floor plan is established, it is prominently displayed in the lower right corner of the screen for easy access. You can open and reference the floor plan at any time, facilitating a seamless exploration of the layout and structure of the environment.
Workflow
Any flat image can be set as a floor plan from the file menu in the tour folder view.
Set and unset the file as a floor plan from the dropdown menu.
A floor map icon appears in the upper right corner of the image, indicating that it has been set as the floor plan.
To make the floor plan interactive and add a mini map to your virtual tour, link the panorama files to the correct place in the floor plan by using hotspots.
Once you link the panoramas, a mini-map appears at the bottom right corner of the screen. Moving between the spaces makes the mini map indicate where you are located on the floor plan.
